Calculating force given a potential
  • Thread starter Thread starter hahaha158
    Force Potential
To calculate the force on a particle given the potential V(r;A,B)=(A/r^14) - (B/r^8), where A=1.5 and B=2/5, the radius vector r can be expressed as r=√(x^2 + y^2 + z^2). The force can be derived using the formula F = -∇V, which can be computed in either spherical or Cartesian coordinates. The electric field is directed radially, either towards or away from the origin, and its magnitude is determined by the derivative of the potential with respect to r. Understanding the relationship between the potential and the electric field is crucial for solving this problem effectively.
hahaha158
Calculate the force on a particle at a position in space
r=[x,y,z]
with A=1.5 and B=2/5
I know how to solve these when there is x,y,z involved, but i am not sure how to deal with something that has r in the equation, cna anyone explain?
Thanks
If the position has coordinates [x, y, z], what's the magnitude of the radius vector, r?
(x^2,y^2,z^2)^.5?
hahaha158 said:
(x^2,y^2,z^2)^.5?
Sorry, I don't understand the notation... are those commas meant to represent "+" operations?
sorry yes i meant to use +.
However i think i may have done it, can you confirm whether or not this is correct?
F= -((-14Ar^-15)+(8Br^-9))*([x,y,z]/r)?
and is this an acceptable form to leave it in?
[x,y,z]/r doesn't match any mathematical notation I'm familiar with (that said, I'm not familiar with every variation of notation or formalism). But I would think that simply resolving r as ##\sqrt{x^2 + y^2 + z^2}## and substituting it for r in the function v(r;A,B) would get you where you want to be.
i should probably have clarified a bit better
this is doing the nabla which i believe is just partial differentation, where you usually have 3 different functions (x,y,z) but since this is r i was a bit unsure. I think i understand it better now after looking some stuff online but thanks for the help regardless!
Okay. Truthfully, I didn't recognize any sign of the ##\nabla## operator being involved. Is the [x,y,z] or V(r;A,B) syntax diagnostic? I'd like to be able to spot the formalism for future reference.
Well I'm not too sure of the syntax, i just tried to convey it as accurately as i can possible to the way i learned it.
I found the answer here
https://docs.google.com/file/d/0B02gF22w0N3nTG1GVzZqOV9VT28/view?sle=true
starting from the top of the 2nd slide to where it says e)i)
You can do E=-∇V in spherical coordinates or you can substitute r=√(x2+y2+z2) and do it in cartesian coordinates.
But there is a much quicker shortcut.
Recall that the electric field is perpendicular to a constant potential surface and the magnitude of the field is simply the rate of change of E in the direction of maximum rate of change.
Your potential function is constant for fixed r, which means the constant potential surfaces are spheres centered on the origin. This means the electric field is a vector pointing either away or toward the origin and its magnitude is just dV/dr -- the rate of change of the potential in the direction it is changing fastest (perpendicular to the sphere, along r).
