Calculating force on the charges placed in the corners of a triangle
The discussion focuses on calculating the forces acting on three charges placed at the corners of an equilateral triangle with sides of 1 m. The charges are defined as e1, e2 = -2e1, and e3 = 3e1, with e1 being 10^-6 As. Initial calculations for the force on charge e1 yielded values of 1.8 N for the interaction with e2 and 2.7 N for e3, leading to a total force of 2.39 N after vector resolution. Corrections were made regarding the cosine component of the force, adjusting the calculations to reflect accurate values. The discussion concludes with participants confirming their understanding of the calculations and methods used to determine the resultant forces and directions.
mmoadi
We place three charges in the corners of the equilateral triangle; the size of the sides is 1 m. Charges are of sizes: e1, e2 = −2e1, and e3 = 3e1, where e1 = 10 ^-6 As. What is the force on the first (second, third) charge and in which direction are they showing?
http://item.slide.com/r/1/20/i/uNrFtWB4tT_sS7zkuV1ExJS_gf3980kJ/
http://item.slide.com/r/1/130/i/1G12EjLq5D8Lo4lU8yYKxmOQfVTQfoSl/
http://item.slide.com/r/1/142/i/dpHAZtcg7j-o-U_uDNFiH60YH-Do8Dwr/
F= k[q(1)q(2)/ d²]
Calculating for e(1):
d= 1 m
F(1,2)= k[q(1)q(2)/ d²] → F(1,2)= 1.8 N
F(1,2-y)= -F(1,2) sin 60º= - 1.56 N
F(1,2-x)= -F(1,2) cos 60º= - 0.4 N
F(1,3)= k[q(1)q(3)/ d²] → F(1,3)= 2.7 N
F(1,3-y)= f(1,3) sin 60º= 2.34 N
F(1,3-x)= -F(1,3) cos 60º= - 1.35 N
F(1-x)= -2.25 N
F(1-y)= F(1,2-y) + F(1,3-y)= 0.78 N
F(1)= sqrt[F(1-x)² + F(1-y)²]= 2.39 N
Are my calculations for e(1) correct?
Thank you for helping!
Have't looked at them all but cos 60=0.5 so not sure where F(1,2-x) came from.
My mistake, it was a typo. here is the correct calculation as I made it:
F(1,2-x)= -F(1,2) cos 60º= - 0.9 N
Now are my calculations correct for e(1)?
My results are different:
Here is how I did force of particle 2 on 1: k= 9.0 E9
total force (2 on 1) = K (1E-6)(2E-6)/1m^2=18 E-3. Since this is attractive force, it is directed upward and rightward.
Fx = F(2-1) cos 60= 9 E-3N
Fy = F(2-1) sin 60 = 0.87 * 18E-3= 15.6 E-3
Do the same for 3 on 1, and then add x components, then Y components and use Pythags formula for total. Direction can be found using tan(angle)=sum y/ sum x
Thank you for helping, I think I understand now :smile:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
