Calculating Heat: How to Apply Calculus for Accurate Results
  • Thread starter Thread starter s7b
    Heat
The discussion focuses on calculating the heat required to raise the temperature of one mole of diamond from 20K to 100K using Debye's Law. The formula C=A(t/θ)^3 is applied to find specific heats at different temperatures, revealing that the heat required increases as temperature rises. The initial approach of summing incremental heat values is deemed incorrect, prompting a suggestion to use calculus for a more accurate result. The proposed method involves integrating the specific heat expression and evaluating it at the specified temperature limits. This calculus-based approach is suggested as a more precise way to determine the total heat required.
s7b
I'm doing some sample problems to prepare for midterm and am stuck on this:
The question talked about many materials at low temperatures obeying Debye's Law C=A(t/θ)^3
it said that for a diamond θ is 1860K and asked to evaluate the specific heats at 20K and 100K.
For this I just used that formula given. The part I'm having trouble with is how much heat is required to heat one mole of diamond between 20K and 100K.
I know that
To heat the diamond from 20 to 21 K, you need:
0.0024 J/molK
from 21 to 22 K, you probably need a little more
0.0026 J/molK ( more or less)
and so on until you heat it from 99 to 100 K where you need:
0.301 J/molK
so you need to add up
0.0024 + 0.0026 + ... +..... + 0.301 to get to the final answer - it should probably look like:
(0.0024 + 0.301) / 2 x (100 - 20 K) = 12.136 J/mol
But this is not the correct answer. How can I apply calculus in order to obtain a more correct answer?
Science news on Phys.org
Well, I have not met that Debye dude, but I think that you need to simply integrate and evaluate the expression at the two limits
your integral would result in something like this: [A/(θ)^3] T^4/4
evaluate that expression at 100 and 20 and subtract such numbers.
does this help? maybe?
This makes more sense then my attempt. Thanks :)
