Calculating Heat Loss and Temperature Drop Using Stefan-Boltzmann's Law
  • Thread starter Thread starter munchy35
    Law
The discussion revolves around calculating heat loss and temperature drop for two teapots made of different materials using Stefan-Boltzmann's Law. The original poster presents a problem involving a ceramic teapot and a shiny teapot, both containing tea at a high initial temperature, and seeks to estimate the rate of heat loss due to radiation and the subsequent temperature drop after a specified time.
  • Mixed
  • Participants discuss the application of Stefan-Boltzmann's Law to estimate heat loss, with some focusing on the necessary conversions for volume and area. Others express confusion regarding the transition from calculating heat loss to estimating temperature drop over time, questioning the appropriate formulas and methods to use.
Some participants have provided insights into the relationship between heat loss and temperature change, suggesting that the rate of heat loss is dependent on temperature. However, there is no consensus on the exact approach to calculate the temperature drop, with ongoing questions about the use of derivatives and integration in the context of the problem.
Participants note issues with unit conversions and the implications of estimating versus calculating exact values. There is an acknowledgment of the complexity introduced by the time-dependent nature of heat loss as described by the Stefan-Boltzmann Law.
munchy35
A ceramic teapot (epsilon(e) = 0.70) and a shiny one (epsilon(e) = 0.10) each hold 0.50 L of tea at 99 degrees C.
a) Estimate the rate of heat loss from each. Consider only radiation, and assume the surroundings are at 20 degrees C.
b.)Estimate the temperature drop after 30 min for each.
change in Q/change in T = epsilon*Stefan constant*Area (T^4 - T^4)
My professor told us to assume that the tea pot is a sphere so we can solve for the area.
so V = 4/3pi R^3 = .05 m^3 R=.2285
A = 4pi R^2 = .6563
Ceramic = (.70)(5.67*10^-8)(.6563)((372^4)-(293^4))
Ceramic = 306.87 W
Shiny = (.1)*5.67*10^-8)(.6563)((372^4)-(293^4))
Shiny = 43.84
Then we're supposed to use two sig figs, which I did,and the program I used keeps telling me I am wrong.
okay so I realized .5 L = .005 m^3
but still I get 66 for ceramic and 9.4 for shiny.
it still says I am wrong
nevermind. i got the right answer.
.5 L = .0005 m^3
gotta work on my conversions!
now i have no idea how to approach part b once i have my answers for part a.
hey I am working on the same problem too and i am stuck on part b and i don't know how to even approach this problem. did u figure it out yet?
In the first part you've worked out the *rate* of heat loss, which is energy dissipated over time, right? So you have (with some notation abuse*):
[tex]H=\frac{E}{T}[/tex]
I may be wrong, but from there, knowing how long the heat was dissipating for (in SECONDS, of course), you should be able to get a change in energy and then temperature...
*Technically this should be a time derivative, as the rate of heat loss is dependent on temperature itself, but...
Yup, Oscur is right. You won't get an exact answer because H should be the time derivative and not E/T, but that's why the question says "estimate".
im still confused. =( so what is the formula to figure out the temperature drop after 30mins? and are we suppose to use derivative to solve this problem? I am so sorry to bother you about this but I am really lost.
are we suppose to use this equation? ---> H = E/T
if so... what is H? E? T?
sooooooo lost.
Ok, basically the rate at which something radiates heat depends on its temperature. This is evident from the form of the Stefan-Boltzmann Law, which has a term in T in it. As a result, to properly calculate the temperature after a given time, you'd need to integrate with respect to time.
As the question says "estimate", however, I'd assume you can just rearrange the equation I gave (in which H is the rate of heat loss, E is a total change in energy and T is a time period, sorry I should have defined my variables and possible the capital T was confusing matters. Call it "t" from now on.)
That way, you have: H*t = E where E is the energy lost by the object. Any more helpful?
  • · Replies 20 ·
