How Do You Calculate the Molar Enthalpy of Formic Acid?
  • Thread starter Thread starter JameB
    Heat Reaction
To calculate the molar enthalpy of formic acid (ΔH°2), the user is analyzing two reactions involving hydronium ions and hydroxide ions, with known enthalpy change for the first reaction (ΔH°1 = -58400 J/mol). The user calculates the moles of H3O+ based on the pH and finds q1 to be approximately 32.12 J. They then attempt to calculate q2 using calorimetry data but express confusion about determining the remaining moles of HCOOH after the reaction. The discussion also briefly diverts to a question about writing a balanced cell reaction equation for a galvanic cell, indicating a misunderstanding of the role of the electrode material. The focus remains on the calculations and methodology for determining ΔH°2.
JameB
I'm doing report for a Thermochemistry lab and I need to calculate the molar enthalpy of formic acid, ΔH°2.
Two reactions are taking place
1) H3O + OH <-> 2H2O with ΔH°1 = -58400J/mol and some q1
2) HCOOH + OH <-> H2O + HCOO and we need to calculate ΔH°2.
I also know the pH is 1.96 before the neutralization took place.
q = nΔH°
qsystem = q1 + q2 = -qsurroundings = -(CcalΔTcal + CvVacidΔTacid +CvVbaseΔTbase)...[2]
So my general approach is:::
First calcualate what q1 is because I know the pH.
[H3O] = 10-1.96
[H3O] = 0.011 M
=> moles of H3O = Vacid*[H3O] = 0.05L * 0.011M = 0.00055 mol H3O {Is this right?}
Then, q = nΔH° = 0.00055mol * 58400 J/mol = 32.12 {does this make sense?}
Now I calculate q2 using equation [2]
Ccal = 76 J/°C
ΔTcal = 6.2°C
Cv = 4.16
Vacid = 50mL
ΔTacid = 6.2°C
Vbase = 50mL
ΔTbase = 5.2°C
q2 = 2842.4J {correct?} Now, ΔH°2 = q2/moles of HCOOHHow do I find the moles of HCOOH? I'm told that "some of the formic acid dissociated and some of the OH reacted with H3O, so you need to determine the mole sof HCOOH left over after the reaction of H3O and OH"
How do I do that? and am I right so far?
It won't hurt if you will tell us what you really did, what are q1 and q2, and what are you expected to determine. We don't know how to read your mind, and what you wrote so far is not enough, it is chaotic and leaves a lot ambiguity. Some things you did are wrong for sure, no matter what you were trying to calculate.
Ignore that whole question, I have a whole new question:
if you have a galvanic cell set up like:
Pt | 0.1M Fe3+, 0.1M Fe2+ || 0.1M AgNO3 | Ag
What does it mean to write a balanced cell reaction equation and how do I do it?
I know that the + electrode was Ag(s) so that means that the cathode was Ag meaning Ag was reduced from Ag2+. So is the answer Pt(s) + Ag2+(aq) -> Pt2+(aq) + Ag(s)?
Please don't pot new questions in old threads, start a new one.
Pt is just an electrode material, it doesn't take part in the reaction.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
