Calculating Heat Transfer for a Water-Cooled Fresnel Lens System
  • Thread starter Thread starter Fritzo130
    Heat Heat transfer
To calculate heat transfer in a water-cooled Fresnel lens system, start by creating a diagram that illustrates the heat flux from the light source to the water block. Use a heat balance equation that accounts for energy input, heat transfer to the block via radiation, and heat loss from the block through radiation and convection. Consider the conduction through the block's thickness and the net heat transfer to the water. Implementing a small program can facilitate the necessary iterations to reach a steady state. This approach will provide a comprehensive understanding of the system's thermal dynamics.
Fritzo130
Hello, everyone,
I have a question on how to calculate the heat transfer and change in temperature for a project I am working on.
It consists simply of a cooling water block (that you would find on a tec cooler etc), a fresnel lens, and a pump.
The fresnel lens focuses the light onto the water block and the water is then pumped through.
Fresnel lens: 13x13" and 50 grooves per inch
Water block: aluminum and a maze channel design. The surface area of contact with the water is known.
Pump: 5 gallons per minute
Any guidance is greatly appreciated!
Thanks,
Fritz Laun
Start by drawing a diagram showing the heat flux from the source to the water exiting the block.
Write the heat balance equation, you should consider the energy source, the heat transferred to the block through radiation, the heat lost by the block surface through radiation and due to convection to the environment, if applicable, heat conducted through the block wall thickness and the net heat transferred to the water.
You can write a small program to make the iterations needed to achieve the steady state.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
