Calculating K.E: 0.0136 J Solution
  • Thread starter Thread starter sfx81
2 replies · 2K views
sfx81
Hi, I am trying to calculate Kinetic energy of system where a mass m(0.20 kilogram) attached at one ond of turntable rotating at 1 revolution per second. The radius of turntable is 6cm.
Here I solve it, please correct
Kinetic Energy = (1/2)mv2
calculating velocity at 1 rpm, and radius = 6cm
so for circumfrance of circle = 2*pi*r
v = 2 * 3.14 * 6cm = 37.69 cm = 0.3769 meters/second
K.E = 0.5 * 0.20 * 0.372 meters
= 0.0136 Joules <=== Is this correct ?
Any help will be appreciated.
Thanks
You need to work out it's rotational kinetic energy.
I = m*(r^2)
I is the moment of inertia of a point mass rotating about a fixed point. Mass of turntable isn't mentioned so assume it is negligible.
E = 0.5*I*(w^2)
E is the energy of a rotating system, where w is angular frequency which is found by:
w = 2*([tex]\pi[/tex])/T
Hi . So If I get it right
mass = 0.02Kg, radius = 6cm = 0.06 meter, frequency = 1 revolution per second
KErotation = I * w2
where w = angular velocity = 2 * pi * f , where f = frequency in revolutions per second.
I = m * r2
K.E rotation = m * r2 * ( 2 * pi * 1)2
= 0.02 * 0.062 * (2*pi*1)
= 2.841 * 10-3 Joules
If this is correct, then how do we equate in the mass of turn table (e.g 0.5 Kg) into equation ? Cause rotational kinetic energy deals with point mass around rotation axis, where as a turn table alone has uniform mass distribution along its surface ?
Thanks
