Calculating Kinetic Energy & Force of a 14kg Projectile
The discussion revolves around calculating the kinetic energy and average force of a 14 kg projectile fired from a 3 m cannon at 630 m/s. The kinetic energy was correctly calculated as 2.8 million Joules, but there was confusion regarding the units, as kinetic energy should be in Joules, not Newtons. The average force calculation was deemed problematic, as it lacks physical significance due to the nature of forces acting on the projectile during its motion. Critics argue that the exercise itself is poorly designed, as it asks for an average force that does not accurately reflect the dynamics involved. Overall, while the calculations were performed correctly, the relevance of the average force question is questioned.
raman911
A 3 m long canon fires a 14.0 kg projectile with a velocity of 630 m/s [F]. Calculate.
A) The kinetic energy of the projectile as it leaves the canon barrel.
B) The average force acting on the projectile in the barrel.
A) Ek=1/2*14kg*630m/s
Ek=2.8*10^6j
B)2.8*10^6j=Fnet*3m
Fnet=2.8*10^6N/3m
Fnet=9.3*10^5N
Is that Right?
Ek=2.8*10^6N
B)2.8*10^6N=Fnet*3m
Fnet=2.8*10^6N/3m
Fnet=9.3*10^5N
Is that Right?
Kinetic energy is not \frac{mv}{2} (though your final number is correct), and its unit is the Joule, not the Newton. Other than that, your approach seems correct.
I can't possibly see the point in exercise B.
Sure, you can average whatever numbers you want, but that doesn't mean anything if the deviations from that average is humungous, as in this case.
The rate of momentum transfer in the initial phase (from the explosion of gun powder) is orders of magnitude higher than the forces acting from the barrel upon the ball during its motion through it.
In addition, those negligible barrel forces are resistive, rather than contributive.
Bad exercise.
Bad exercise.
your mean B is wrong
No, I mean that the exercise is dumb, not that you have made a mistake.
He means that the question is asking you to determine a quantity which has little physical significance. Even if you calculate the average force acting on the bullet as kinetic energy is added to it, you will be stuck with a value that means nothing.
But this is the fault of the question, and not the fault of your answer.
thxxxxxxxxxxx
