Calculating Ksp of salt (answer check)
  • Thread starter Thread starter ScrubsFan
    Ksp Salt
The discussion focuses on calculating the solubility product constant (Ksp) for two salts: calcium sulfate (CaSO4) and magnesium fluoride (MgF2). For CaSO4, the Ksp is determined to be 1.2 x 10^-5 based on the dissociation into calcium and sulfate ions. Initially, the Ksp for MgF2 was incorrectly calculated, but it was corrected to account for the dissociation into one magnesium ion and two fluoride ions. The final Ksp for MgF2 is calculated as 1.5 x 10^-5. The thread emphasizes the importance of accurately representing ion dissociation in Ksp calculations.
ScrubsFan
69. Calculate the Ksp for each of the salts whose solubility is listed below.
a) CaSO4 = 3.3 x 10-3 mol/L
b) MgF2 = 2.7 x 10-3 mol/L
Answers:
a) Solution
1. Write the dissociation reaction and the Ksp expression for the equilibrium reaction. Thus,
CaSO4(s) <---> Ca2+ (aq) + SO42- (aq)
Ksp = [Ca2+][SO42-]
2. Calculate the concentrations of the ions at equilibrium from the stoichiometric information provided in the equilibrium equation. The equation shows that 1 mol of CaSO4 produces 1 mol of Ca2+ and 1 mol of SO42- at equilibrium. Therefore,
[Ca2+] = 3.3 x 10-3 mol/L
[ SO42-] = 3.3 x 10-3 mol/L
3. Substitute the concentrations into the Ksp expression:
Ksp = (3.3 x 10-3)( 3.3 x 10-3)
= 1.2 x 10-5
b) MgF2 <---> Mg2+ (aq) + F22+ (aq)
Ksp = [Mg2+][F22+]
[Mg2+] = 2.7 x 10-3
[F22+] = 2.7 x 10-3
Ksp = (2.7 x 10-3)(2.7 x 10-3)
= 7.3 x 10-6
your first one looks right, but the F2 in the second equation will actually dissociate into two F- ions
Alright I fixed part b), is it right now?
MgF2 <---> Mg2+ (aq) + 2F- (aq)
Ksp = [Mg2+][F-]2
[Mg2+] = 2.7 x 10-3
[F-] = 2 x 2.7 x 10-3
Ksp = (2.7 x 10-3)(5.4 x 10-3)
= 1.5 x 10-5
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
10K
