Calculating Linear Acceleration on a Rotating Record
To calculate the linear acceleration of a point on the rim of a rotating record, the correct formula for centripetal acceleration is ac = ω²r. For a record with a diameter of 30 cm rotating at 33.5 rev/min, the radius is 0.15 m and the angular velocity is 3.49 radians/second. Using these values, the centripetal acceleration is calculated to be 1.8 m/s², which matches the book's answer. The confusion arose from misapplying the formula for radial acceleration. The discussion highlights the importance of using the correct equations in rotational motion problems.
jenavira
Q: What is the linear acceleration of a point on the rim of a 30-cm-diameter record rotating at a constant angular speed of 33.5 rev/min?
I seem to have all the variables and equations in hand -
r = .15m and \omega = 3.49 radians/second;
v = \omega r ;
(radial component of linear acceleration) a_r = \frac {v^2} {r} \omega^2 r
...but I get 3.29 \frac {m} {s^2} (pointing inward), and the book's answer is 1.8 \frac {m} {s^2}. Am I wrong? Is the book wrong? Did I just convert something wrong somewhere? I'm very confused.
I got 1.8. You need to use the equation for centripetal acceleration (since the record is spinning) and that is ac= angular velocity^2 times radius. That should give you your answer!
*facepalm* Figured it was something simple like that. Thanks!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
