Calculating load for tidal movement
Calculating tidal movement load involves using wind load formulas, specifically wind speed squared multiplied by 0.00431 and the area in square feet. For example, a 5 mph wind on a 100 sq. ft. surface results in a force of 10.77 lbs. The mass of salt water being approximately 854 times that of air raises questions about adapting wind load calculations for water. Different atmospheric conditions may also influence the weight of water, necessitating adjustments in calculations. Various standards and coefficients, such as those in API 2SK, are essential for accurate force assessments on ocean vessels.
jamesd442001
Calculating wind load is wind speed squared x .00431 x area in sq. ft. A 5 mph wind with a vertical 100 sq. ft. wing is 10.77 lbs. The mass of salt water is around 854 times greater than the mass of air. Can you use the wind formula and multiply by 854? Does the weight of water at different atmospheres change this?
What is the context of this question? Various standards would apply and have things such as shape coefficients that will change the resultant force from environmental loadings.
The type of hull (presumably this is for an ocean vessel) may also introduce other factors to consider.
That being said, the final calculation will be some derivative of the basic equation:
F = PA
API 2SK is a good reference for this. For a ship hull the current force on the bow or stern (in lbf) is:
F_{cy} = C_{cy}SV_c^2
where,
S = wetted surface area of hull including appendages (ft^2)
V_c = current speed (knots)
C_cy = current force coefficient = 0.40 lbf/(ft^2 - knots)
Hope this helps.
CS
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
