Calculating Magnetic Flux in 3D
The discussion centers on calculating magnetic flux in three-dimensional space, specifically relating magnetic flux density to distances in the x, y, and z directions, as well as connecting magnetic flux density to the pulling force exerted by magnets. The scope includes theoretical and mathematical reasoning.
  • One participant seeks a formula to relate magnetic flux density with distances in the x and y directions, in addition to z.
  • Another participant notes that the force exerted by a magnet depends not only on the magnetic field but also on the characteristics of the object being pulled or pushed, questioning whether it is another magnet or a piece of iron.
  • A participant suggests using a piece of ferrite for simplicity, but indicates that a piece of iron could also be used.
  • One participant outlines a method for calculating the force between two magnetized hard ferrites, detailing steps involving magnetization, division into small domains, and the use of magnetic moments to compute forces.
  • The proposed method includes a formula for the force acting on magnetic moments and a way to calculate the total force as a sum of interactions between all pairs of moments.
Participants express differing views on the complexity of the problem and the methods to approach it, indicating that multiple competing views remain without a consensus on a single solution or formula.
The discussion includes assumptions about uniform magnetization and the specific characteristics of the materials involved, which may affect the applicability of the proposed methods.
OrenKatzen
Hi everybody,
first time poster here. I am working on calculating the force of magnets in a 3 dimensional space. I have found a formula for the magnetic flux density at a distance z from the magnet face at this link http://www.magneticsolutions.com.au/magnet-formula.html, under Flux density at a distance from a single rod magnet.
My problem is that I can't find a formula which will relate the magnetic flux density with distances in the x and y directions as well as z. Does anyone know of a formula or way to figure this out?
On a similar note, how do I then relate magnetic flux density to the pulling force at that distance?
Thanks!
Welcome to PF!
The force the magnet will exert does not depend only on the magnetic field of the magnet, but also on the object that is pulled/pushed. What is it? Another magnet, or piece of iron?
I am probably pulling a piece of ferrite, but if it's simpler, we can just make it a piece of iron.
The problem is quite difficult in general. If both pieces are magnetized hard ferrites - magnets (have permanent magnetization), here is what I would do:
0. find out the magnetization ##\mathbf M## of both pieces; in the simplest case, each magnet has uniform magnetization, so just there are just two vectors, one for each magnet;
1. divide both the magnet and the ferrite into small domains (cubes) ##i## with volume ##\Delta V_i##;
2. the magnetic moments ##\mathbf m_i## can be found as ##\mathbf m_i = \mathbf M(i) \Delta V_i##, where ##\mathbf M(i)## is the magnetization at i;
3. there is a formula for the force acting on the moment i due to the moment j:
\mathbf F(i) = - \mathbf m_i \cdot \nabla \mathbf B_j(\mathbf x_i)
where ##\mathbf B_j(\mathbf x)## is the magnetic field due to the moment j:
\mathbf B_j(\mathbf x) = \frac{\mu_0}{4\pi} \frac{3\mathbf n(\mathbf n\cdot \mathbf m_j)- \mathbf m_j}{|x-\mathbf r_j|^3}
and ##\mathbf n = \frac{\mathbf x-\mathbf r_j}{|x-\mathbf r_j|}##
4. total force = sum of the forces between all pairs (i,j), where i comes from the first magnet, j comes from the second magnet.
  • · Replies 24 ·
  • · Replies 27 ·
  • · Replies 27 ·
  • · Replies 198 ·
16K
  • · Replies 26 ·
9K
