Calculating Magnetic Force on a Moving Charge near an Infinite Straight Wire
  • Thread starter Thread starter eestep
    Infinite Wires
An infinite straight wire carrying a current of 73 x 10^7 amps generates a magnetic field affecting a moving charge of -4 micro-Coulombs. The charge is moving at 3 x 10^6 m/s at coordinates (1.9 m, 4.5 m). The magnetic field strength calculated is 29.89 T, but the angle between the velocity and magnetic field must be considered for accurate force calculation. The missing sine component of the angle leads to an incomplete force equation. The correct magnitude of the magnetic force on the charge is determined to be 139.51 Newtons.
eestep
An infinite straight wire is located at origin of a coordinate system. It has a large current of 73 x 107 amps running positive z direction. A point charge of -4 micro-Coulombs is moving at 3 x 106 m/s in positive x direction at point x=1.9 m, y=4.5 m. What is magnitude of magnetic force on this charge in Newtons? Answer is 139.51.
B=\mu0I/(2\pir)
FB=qvBsin\theta
B=(4\pi x 10-7 Tm/A)(73 x 107 A)/(2\pi)(4.88m)=29.89 T
FB=(4 x 10-6 C)(3 x 106 m/s)(29.89 T)sin(67.11)
θ is the angle from the direction of vector qv and to the direction of vector B.
sinθ is missing from your answer.
Very simple: you didn't took into account that the velocity is not totally orthogonal to the direction of the magnetic field, i.e. you didn't multiplied with sinLaTeX Code: \\theta.
The direction of the magnetic field is tangential to the radius, your radius is the vector (1.9, 4.5)m, you need to find the orthogonal direction to this vector.
**@SammyS beat me to it :)
