Calculating Mass Ratio in Collision of Two Carts
The discussion focuses on calculating the mass ratio of two colliding carts using the principle of momentum conservation. The initial momentum of the moving cart is set equal to the final momentum after the collision, leading to the equation 18m1 = -4m1 + 8m2. Solving this gives a mass ratio of 0.36 for m1/m2, which contradicts the book's answer of 1/2. Participants question the accuracy of the problem transcription and the provided solution. The conversation emphasizes the importance of verifying calculations and source material in physics problems.
bigsaucy
Two carts each 12 cm long travel toward each other on a frictionless air glider track. The first cart on the left has an initial velocity of 18 cm/s toward the other cart that is stationary. The carts then collide. The cart on the left has a new velocity of -4cm/s and the stationary cart now has a velocity of 8 cm/s. Calculate the ratio of m1/m2 where m1 and m2 are the masses of the two carts. (momentum is conserved in the system)
I used the fact that momentum is conserved in the system to write the expression:
P final = P initial
or in other words, since initially only the cart on the left is moving, 18m1 = -4m1 + 8m2
which whne solved leads to the expression 0.36 = m1/m2; the book however says the answer is 1/2.
Pls help?
P final = P initial
Pls help?
My answer agrees with you. Are you sure you've transcribed the question correctly from the source? Sure you are checking the right one in the answers?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
