Calculating Masses from Disc Explosion Velocities
  • Thread starter Thread starter puregoodboi
    Disc Explosion
The discussion centers on calculating the mass ratio of two discs propelled apart by an explosion, with velocities of 9.0 m/s and 5.0 m/s. The ratio is derived using the principle of conservation of momentum, leading to the conclusion that the first disc has 5/9 the mass of the second. There is confusion regarding an answer key that states the mass ratio as 0.36, which does not align with the calculated ratio. Participants speculate on potential errors in either their calculations or the answer key. The conversation highlights the importance of understanding momentum in solving such physics problems.
puregoodboi
Two frictionless discs on air table, initially at rest, are driven apart by an explosion with velocities of 9.0m/s and 5.0m/s what is ratio of masses?
how do i get masses if i don't know Momentum ? +__+
m1u1=m2u2 Since we want the ratio of m1 and m2 we make m2=m1*k(a constant)
m1(9m/s)=m1*k*5m/s
k=9/5 So the ratio of the two masses is that the 1st has the 5/9 of the seconds mass
m1(9m/s)=m1*k*5m/s
the answer key says its 0.36 .. why's that?
I have no idea...maybe they made a mistake or I did one...lol
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
