Calculating max velocity of car
The discussion revolves around calculating the maximum velocity of a solar-powered car being built using solar panels and bike hub motors. Participants explore various parameters such as mass, tire size, torque, RPM, and rolling resistance to estimate the vehicle's speed.
  • One participant provides initial specifications for the car, including mass, tire diameter, rolling resistance, torque, and RPM, and seeks guidance on calculating maximum velocity.
  • Another participant notes that the maximum speed will depend on both aerodynamics and rolling resistance, suggesting that aerodynamics should be prioritized in the design.
  • A different participant clarifies that the rolling resistance value is in Newtons, specifically 13 N, and expresses confidence in the car's design regarding aerodynamics due to its structure.
  • Concerns are raised about the claimed power output of the solar panels, with one participant questioning the feasibility of achieving 820 watts without a large surface area.
  • One participant shares results from a physics program that estimates a maximum speed of 7 m/s based on adjusted torque and RPM values, asking if these numbers are reasonable.
  • Another participant suggests a straightforward method to calculate speed by multiplying RPM by tire circumference, prompting further calculations from others.
  • Discussions about the conversion of RPM to speed reveal confusion, with participants attempting to clarify the calculations and units involved.
  • One participant ultimately expresses satisfaction with a calculated velocity of approximately 3.8 m/s, indicating that they are not seeking high speeds.
Participants express varying levels of confidence in the calculations and assumptions made regarding speed, torque, and power output. There is no consensus on the accuracy of the initial power output claims or the resulting speed calculations, leading to multiple competing views and unresolved questions.
Participants highlight potential inaccuracies in the torque values and the need for clearer definitions of terms like rolling resistance and tire circumference. There are also unresolved issues regarding the estimation of air resistance and its impact on maximum speed.
Individuals interested in solar-powered vehicle design, physics students exploring vehicle dynamics, and hobbyists working on similar projects may find this discussion relevant.
Bindle
Hey! I have a project where I'm building a car running from direct sun-light only using solar-panels and bike hub motors.
I would like to determine max velocity before cashing out on motors and panels. I have some numbers from the panels and motors I looked on, how do I turn them into the max velocity of my vehicle?
Mass: 200 kg
Tire diameter: 12" or 30.48 cm
Rolling resistance: 13.748
Torque: 33 N.m
RPM: 120 or 240
Gear ratio: Not sure if it's necessary since there is no gears and the wheel is running directly on the motors axis.
Diff ratio: I guess it's 1 since there is no gears.
Some of the numbers like the torque may be inaccurate since I have got it from some calculators in the internet.
Thanks
//Bindle
Mass: 200 kg
units?
Torque: 33 N.m
At what speed?
RPM: 120 or 240
Thanks
//Bindle
The maximum speed will depend on the aerodynamics of the body of your car as well as the rolling resistance. You will find that the torque produced by the electric motors depends on their speed and load. I would suggest that you work on making the car as aerodynamic as possible first. You will need enough surface area to generate the power you will need and you need to incorporate those panels into your car while maintaining an aerodynamic shape.
AM
The rolling resistance is in N so only 13 Newtons.
Aerodynamics will not be so much of a problem I think, because it will have two panels as a roof and light-weight steel frame with four wheels, a steering-wheel and a seat.
I have some diagrams which maybe can be of help:
http://www.electro-mobile.se/uploaded/project/documents/281/Datablad 4033.jpg This is a 12" wheel which uses a hubmotor.
http://www.electro-mobile.se/uploaded/project/documents/282/Pie48V.pdf This is a 16" hub motor with a wheel attached.
And this is the last one, a 12" hub motor with a wheel attached: http://www.electro-mobile.se/uploaded/project/documents/359/E4037-211data_a.pdf
The wattage my panels will generate is 820 watts and max amp of 16, and 48 volts.
Just wondering about one of your figures: 820 W is quite high. The best commercial panels produce about 175 W per exposed square metre in sunshine. This would suggest that you have a panel area of over 4 square metres (that is over 40 square feet).
The car's maximum speed is the power output from the motor (which will be somewhat less than the power from the panels) divided by the resistive force, Fres, on the car. Fres: is partly made up of rolling resistance (roughly constant) and partly of air resistance of various sorts, which increases with the car's speed. Unfortunately, it's quite difficult to estimate how large the air resistance will be at different speeds, but you've got to have some sort of estimate in order to find the maximum speed of the car!
Sorry not to be more helpful.
Every bit helps. Thanks for replying. Alright, well I used a physics program called Algoodo and I used the numbers 18 Nm as torque and 240 rpm to the wheel-axis and it did a speed of 7 m/s or 35 km/h, 21 miles/h and that program has air-resistance built in and rolling resistance. Is those numbers reasonable? I had 200 kg as load and 16" wheels.
I know the panels will be big. I have two 410 watt panels which is 2 x 1,64 m each. So the roof will be 6 square meters approximately, big roof!
With such a low motor rpm, you may not have to consider anything else! Just multiply it by tire circumference to find speed.
Sweet, I used this calculator:
http://www.csgnetwork.com/tiresizescalc.html
and came up with: 51.365 in tire circumference.
Tire width: 44.45 mm
Tire Height Factor: 10 , Using this as reference: http://www.bicycletires.com/pch16i/cheng_shin_general_style_16x175_tire/pp.htm
Rim diameter: 16"
So multiply 240 * 51.365 = 12327.6
Is that 12.3 m/s or is there numbers which are wrong?
Maybe I have misunderstood it some.
That's revolutions per MINUTE, right? So your answer can't be in m/s...
Right! So 240 RPM is 4 Revolutions per second if divided by 60.
However let's say we have 240 RPM and 51.365 and it turns to 12327.6 m/m that would be
12327/60 = 205.45 m/s Can't be right.
But if it would be every hour then it would be:
(12327/60)/60 which is 3.42 m/s
But this can't be right either.
Somehow when you found your minutes, you lost your millimeters:
12,237 mm/min / 60 sec/min = 0.20 m/sec.
Still, not sure how you found circumference. Converting diameter to circumference just requires multiplying by pi. So I get 30.5*3.14=95.7 cm. So 95.7/100*240/60= 3.8 m/sec.
Ah, circumference it's just the length around the circle, didn't know that word in english. Sweet. That seems like an ok velocity, not looking for high speed.
Thanks!
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 95 ·
  • · Replies 23 ·
12K
