Calculating Minimum Speed for Ballistic Pendulum with Attached Mass
The discussion focuses on calculating the minimum speed of a wad of putty required to make a suspended stick rise to a horizontal position after a collision. The problem involves applying conservation of momentum and energy principles, with the angular momentum of the putty being a key factor. The moment of inertia is calculated using the formula I = (1/3)M*d^2 + m*r^2. The user attempts to solve the equations but arrives at an incorrect speed of 33.39 m/s, indicating a misunderstanding in the application of the center of mass and height in the energy conservation equation. The discussion highlights the complexities of the calculations involved in this physics problem.
ArticMage
A uniform stick d = 1 m long with a total mass of 249 g is suspended vertically from a frictionless pivot at its top end. A wad of putty of mass 29 g is moving horizontally with speed v. It strikes and sticks to the stick at a distance 0.75 m from the pivot.
What is the minimum speed of the putty such that the stick, with the putty stuck to it, will rise to the horizontal position?
L=m*v*r
L=I*w
.5*I*w^2=m*g*h
Conservation of momentum applies so first I have the angular momentum of just the putty with respect to the axis of the rod.
L=m*v*r
then just after the collision the rod has a angular momentum of
L=I*w
this gives me m*v*r/I=w which I use in a bit
The I = (1/3)M*d^2+m*r^2
Next, after the collision i use conservation of energy.
.5*I*w^2=(M+m)*g*h
h=cm=(M*d+m*r)/(M+m)
solving the above for w i get sqrt((2*g(M*d+m*r)/I)
now back to w=m*v*r/I gets me I/(m*r)*sqrt((2*g(M*d+m*r)/I) = v
this gets me 33.39 m/s which is wrong.
I tried without the cm stuff and just had h= 1 but that gets just about the same answer just a littler higher and also wrong.
The center of mass of the stick is at d/2, not d. :smile:
argh why is it always something so simple.
thanks for the help though.
