Calculating Momentum and Energy Conservation in Elastic Collisions
The discussion revolves around calculating momentum and energy conservation in elastic collisions, specifically focusing on the application of conservation laws in different directions and the implications of vector quantities in momentum calculations.
  • Participants explore the application of conservation of momentum in various directions, questioning how to approach the problem specifically in the direction of mass m1. There is discussion about the advantages of using x and y components for simplification.
Participants are actively engaging with the concepts of momentum and energy conservation, with some offering hints about starting points and considerations for solving the problem. Multiple interpretations of the problem setup are being explored, particularly regarding the use of the center of momentum frame.
There is an emphasis on the need to conserve both momentum and kinetic energy in elastic collisions, with participants noting the importance of accounting for vector components and the implications of unknown variables in the equations.
Shivam
Can you find the magnitude of V1' by applying conservation of linear momentum along the direction of motion of m1 after collision ?
(M1)U1 +(M2)U2 = (M1)V1 +(M2)V2
I know how to solve along x and y-axis but i can't think of how to start solving in the dricection on m1.
You could apply conservation of momentum in any direction. But using x and y has its advantages -- the equations are a bit simpler.
What do you mean by soliving in the direction of m1?
Momentum is a vector quantity. That means, it has components as does velocity. So you need to total up the momentum in each direction before, then after. It has to be the same before as after in each direction.
At the same time, assuming an elastic collision, you need to conserve energy. So before you have kinetic energy of m1. After you have a different kinetic energy for m1, and a new one for m2. The before and after need to be equal.
So you will get an x-direction momentum equation, a y-direction momentum equation, and an energy conservation equation. These will involve the magnitude of the after-velocity of each mass (two unknowns) and the two angles.
Here's a hint. Start in the center of momentum frame. In that frame the two masses start with equal-but-opposite momentum. And they finish with equal-but-opposite momentum at some other angle. Then get your final answer and transform back to the lab frame.
  • · Replies 16 ·
  • · Replies 22 ·
