Calculating phase velocity in a material
Calculating the wavelength of an electromagnetic wave in a medium involves understanding phase velocity, expressed by the formula vphase = c/(sqrt(εr*μr)). The wavelength is then determined using λ = vphase/f, where f is the frequency. The discussion highlights the complexity of permittivity, noting that it can have both real and imaginary components, with the real part (ε') related to energy storage and the imaginary part (ε'') associated with energy loss. This complexity suggests that a comprehensive understanding of permittivity is crucial for accurate calculations in various media. The conversation emphasizes the importance of recognizing the frequency dependence of the dielectric constant in practical applications.
Julle
Calculating wavelength in a media
Hi
Trying to get how to calculate the wavelength of an electromagnetic wave in a media and I am getting confused about the permittivity.
I know the formula:
vphase = c/(sqrt(εrr))
where vphase is the phase velocity.
c is the speed of light in a vacuum.
εr is the relative permittivity.
μr is the relative permability.
Then to get the wavelength we do like this:
λ = vphase/f
where λ is the wavelength and f the frequency.
This is all well and good, but isn't there a real and imaginary part to the permittivity? Is only the real part used or is the entire complex number used in which case you end up with a complex distance??
I've never heard of it being anything but real? Can you cite something that causes you to think it is a complex number?
http://www.random-science-tools.com/electronics/water_dielectric.htm
One of many but shows the principle nicely.
The dielectric constant is for most (all?) dielectric materials frequency dependant and is often written as εr=ε'-iε''
where ε' is the real part and is related to the stored energy inside the medium
ε'' is the imaginary part and related to the loss inside the medium
https://en.wikipedia.org/wiki/Permittivity
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
