Calculating Radiation View Factor for Various Shapes
  • Thread starter Thread starter Baltistani
    Radiation Shapes
The discussion focuses on calculating the radiation view factor for various geometric configurations, including flat surfaces, spheres, and concentric spheres. Participants suggest consulting standard heat transfer textbooks for established formulas, particularly for concentric spheres. It is noted that view factors can be determined through area or contour integrations, although caution is advised with contour integration when distances between differential elements are small. The conversation emphasizes the importance of understanding the geometry involved in these calculations. Accurate calculation methods are essential for effective thermal analysis in engineering applications.
Baltistani
how is radiation view factor calculated especially for the following cases
1-between a flat surface and a sphere
between two flat surfaces at 90
between two surfaces facing each other
between two spheres
How I could calculate veiw factor between two sphere tahat are concenteric
please help me
thank you
shoaib85: please refer to any standard book on heat transfer, view factor between concentric spheres can be easily found out using view factor algebra.
Baltistani: View factor between any pair of surfaces can be found by performing 4 area integrations or 2 contour integrations, but I'm not sure if contour integration can be used always, especially when the distance between any two differential element on both surface is less than unity since it gives negative results.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
