Calculating Ratio of Electron and Positive Ion Mean Free Paths in an Ionised Gas
RichRobX
Question goes as follows:
"In an ionised gas there are positive ions and electrones moving around in collision with molecules of the gas. Calculate the ratio of the mean free path of the electrons in the gas to the mean free path of the positive ions in the gas."
As far as I can see I only need
lamda = (KT)/(4pi root2 r^2 p)
where everything will cancel except r giving r1:r2 ratio
I could assume r is roughly 1x10^-10 for the molecules, but I don't think I'm supposed to know or find r for the electron since the compton radius ( (e^2/(me c^2) ) is a little beyond what we've done.
What have i missed..?
- Rob
Hi RichBoxX,
The r in your mean free path formula refers to the radius of the molecules with which the electrons collide. See here for details: http://hyperphysics.phy-astr.gsu.edu/hbase/kinetic/menfre.html
If the gas is only somewhat ionized, the mean free path is dominated by collisions of electrons with non-ionized molecules and you can ignore the collisions of electrons with positive ions.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
It's given a gas of particles all identical which has T fixed and spin S. Let's ##g(\epsilon)## the density of orbital states and ##g(\epsilon) = g_0## for ##\forall \epsilon \in [\epsilon_0, \epsilon_1]##, zero otherwise. How to compute the number of accessible quantum states of one particle? This is my attempt, and I suspect that is not good. Let S=0 and then bosons in a system. Simply, if we have the density of orbitals we have to integrate ##g(\epsilon)## and we have...
