Calculating Resultant Force of 2 Fluids in a Tank
To calculate the resultant force on the vertical walls of a tank filled with water and light oil, the water reaches a height of 1.2 m while the oil extends to a total height of 2 m. The pressure at the oil-water interface must be considered, as the oil, being less dense, does exert some pressure on the water below. The calculation involves integrating the forces from both fluids separately, with the water's force calculated from 1.2 m to 2 m and the oil's force from 0 to 0.8 m. It is essential to recognize that the oil does apply pressure to the water, albeit less than a denser fluid would. Understanding the interaction between the two fluids is crucial for accurate resultant force calculations.
stuharis
1. A tank with vertical walls, 2m wide and 2m long and 2.5m high, is filled with 4800 litres of water (density 1000 kg/m3) and 3200 litres of light oil (density 900 kg/m3). Calculate the magnitude and location of the resultant force on each of the vertical walls of the tank.
2. By doing some simple math the water goes up to 1.2 m of the tank and the oil continues further to a combined height of 2 m.
I solve this kind of problems by taking dF= ρghwdh. For the oil I take the integral from 0 to 0.8 and for water i take the same integral from 0.8 to 2. Then I find the moment for the side with the same way and through that i find the position of the force.
I know the solution is right for a single fluid. But is this right for 2 or more fluids on top of each other?
Hint: what is the pressure at the oil-water interface? Do you think that the oil is heavier than the water?
I think the oil is above the water. What is bothering me is, if the water force is equal to dF=ρwghwdh from 1.2 to 2 or should i also add the force that the oil apllies to the water and use df=ρwghwdh(this integral from 1.2 to 2) + ρoghwl to add the pressure the oil adds?
ρw=density of water
ρo=density of oil
I guess you will need to decide whether it makes sense or not for the oil to press down on the water. :)
Yeap but I cannot really decide :S
Since oil stands on top of water isn't it logical to apply some pressure to the water?
Does anyone know?
It is logical, yes.
If it were just more water above the 1.2 m mark, it would contribute downward force and hence be part of the 'h' in the hydrostatic pressure ρgh. This is oil which weighs a little less, so it contributes a little less downward force (but not that much less!).
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
