Calculating resultant forces given FBD
The discussion centers on calculating the forces acting on a truck with a mass of 8000 kg accelerating up a 4-degree incline at 5.0 m/s², while facing a friction force of 5500 N. Participants clarify that the net force (F_net) should be calculated by considering all forces acting on the truck, including gravity, friction, and the force exerted by the truck on the road. The importance of breaking down forces into x and y components is emphasized, particularly for the incline scenario. Participants explore the correct application of Newton's second law, leading to the realization that the total force exerted by the truck must account for both friction and the gravitational component down the incline. The conversation concludes with a focus on accurately determining the forces to solve for the truck's motion.
cdn88
A truck of mass 8000 kg is accelerating at 5.0 m/s2 up a hill of inclination 4 degrees to the horizontal The friction forces on the truck add up to 5500 N.
What force does the truck exert against the road in the direction of travel?
What force does the road exert on the truck in the direction of travel?
With the truck's engine working just as hard, what would be the acceleration of the truck down the hill?
F=ma
For the force the truck is exerting i used F=ma so F=(8000)(5)=40 000N
I just don't believe it's that simple, do i need to break down the incline into x and y components? In which case I am not given enough information..
t
F=ma
you are mis-stating Newton's 2nd law. It's F_net =ma. F_net consists of several forces. What are they? You have all the info you need.
PhanthomJay said:
tyou are mis-stating Newton's 2nd law. It's F_net =ma. F_net consists of several forces. What are they? You have all the info you need.
The forces are normal, gravity, friction, and the trucks excretion on the road, normal and gravity cancel, so i need to incorporate friction?
another thought, 5500N cos 4 and 5500N sin 4 give me x and y components of friction, I am just thinking about how to apply this to the equation.
Well, Yes!,but when you are looking at the forces on the truck,you are looking at the force exerted by the road on the truck, the Earth on the truck,the normalforce on the truck,and the friction on the truck
No!
Yes, and the gravity component down the plane.
When you are dealing with problems involving inclines, it is most often best to choose the x-axis parallel to the incline, and the y-axis perpendicular to the incline. It makes life a lot easer. You just have to tilt your head and watch your geometry and trig. So you have the truck force along the x direction parallel to and up the incline, and the friction force along the x-axis parallel to and down the incline; now you just need to know the component of the gravity force down the incline,and use Newton 2 to solve for the force exerted by the road on the truck. Then what about the force exerted by the truck on the road??
And welcome to PF!
ok, thank you! so i set up the incline to be the xaxis. now, the force of gravity is found by f = mg ((8000)(9.8) = 78400 so 78400 sin 4 = 5468.9 which is the x component of the gravity force?
so, does f_net=ma mean 40000 is the total force so i subtract gravity force and friction to find what the truck is exerting to move 5m/s up the incline?
if so, 40000-5500-5441= 29059 N am i on the right track?
thank you for your help.
edit: or wait, if 40000N is the force needed to maintain 5m/s^2 for 8000kg then i may have to add the forces of gravity and friction?
edit2: i believe my last edit is wrong.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
