Calculating Speed & Kinetic Energy of Two Cars Colliding
  • Thread starter Thread starter dj_killer_lamb
    Cars
In the collision of two 2000kg cars, the combined speed after they stick together is calculated to be 20 m/s using momentum conservation principles. The initial kinetic energy of the system is determined to be 1,000,000 J, but there is confusion regarding the kinetic energy after the collision. The calculations incorrectly suggest that the kinetic energy after the collision is 1,600,000 J, which is not possible as energy cannot be gained in an inelastic collision. The errors stem from incorrect mass summation and neglecting the square of the velocity in the kinetic energy formula. Clarification on these points is essential for accurate energy loss calculations during the collision.
dj_killer_lamb
A 2000kg car traveling to the right at 30 m/s is chasing a second car of the same mass that is traveling to the right at 10 m/s
1) if the two cars collide and stick together, what is their speed after the collision?
2) What fraction of the initial kinetic energy of the cars is lost during this collision?
Ok so I'm pretty sure I've got the first question answered using the formula for calculating momentum (Momentum = Mass * Velocity) but I'm having a bit of trouble answering question 2. The collision should result in a loss of kinetic energy but I've come up with an answer that says it has gained kinetic energy :S.
Here is the work I have done thus far:
1) Momentum Before = (2000kg * 30m/s) + (2000kg * 10m/s)
= 80, 000 kg m/s
therefore V after = (Momentum1 + Momentum2)/(Mass1 + Mass2)
= 80,000kg m/s / 4000kg
= 20m/s
2) KE1 = 1/2 MV^2
= 1/2 2000 * 30^2
= 900,000 J
KE2 = 1/2 MV^2
= 1/2 2000 * 10^2
= 100,000 J
Therefore total initial KE = 1,000,000 J
Therefore KE after = 1/2 (m1 + m2) * (total velocity)
= 1/2 8000 * 20
= 1,600,000 J
Any help would be greatly appreciated!
= 1/2 8000[/color] * 20
= 1,600,000 J
This doesn't look correct for the sum of the masses of the two vehicles.
yea perfect til the last few lines, the square of velocity was dropped as well. plus the math went awry, even if the terms were wrong.
LOL! arrrg of course! I don't know where that 8000 came from! Thanks heaps :)
Thanks a lot guys, i nailed my spoken today...would have taken me forever to pick up on those errors!
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
