Calculating strain from wave speed and tension in a wire
An aluminum wire under zero tension has its tension increased by reducing the temperature, affecting its equilibrium length. The transverse wave speed is given as 100 m/s, with the wire's cross-sectional area at 5.0 x 10^-6 m², density at 2.7 x 10³ kg/m³, and Young's modulus at 6.8 x 10¹⁰ N/m². The calculations show that the mass per unit length (μ) is 1.35 x 10^-2 kg/m, leading to a tension (τ) of 135 N. The correct strain (ΔL/L) is calculated to be 4.0 x 10^-4 after verifying unit consistency. Accurate unit tracking is emphasized to avoid mistakes in calculations.
hs764
Just wanted to check my work on this one.
An aluminum wire is clamped at each end under zero tension at room temperature. The tension in the wire is increased by reducing the temperature which results in a decrease in the wire's equilibrium length. What strain (ΔL/L) will result in a transverse wave speed of 100 m/s? Take the cross-sectional area of the wire to be 5.0 x 10-6 m2. The density of aluminum is ρ = 2.7 x 103 kg/m3 and Young's modulus is Y = 6.8 x 1010 N/m2.
[/B]
v = √(τ/μ), F/A = E(ΔL/L)
[/B]
100 m/s = √(τ/μ) μ = ρ x A = 2.7 x 103 kg/m3 x 5.0 x 10-6 m2 = 1.35 x 10-2 kg/m. τ = v2μ = 1 x 104 m2/s2 x 1.35 x 10-2 kg/m = 135 N = F/A. F/A = E(ΔL/L), 135 N = 6.8 x 1010(ΔL/L). ΔL/L = 2.0 x 10-9.
Does this look correct?
135 N ≠ F/A
Check your units.
Oh, right...F/A would be 135 N / 5.0 x 10-6 m2 = 2.7 x 107 N/m2?
Correct.
I always strongly recommend to include all your units in all your calculations. That way you can catch easy mistakes like this.
So ΔL/L = 4.0 x 10-4?
Looks about right.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
