Calculating temp rise caused by electric arc in an enclosed space
To calculate the change in gas temperature in a closed space due to an electric arc, one must first determine the energy delivered to the gas, which is the product of the electrical power and the duration of the arc. This energy contributes to both the light emitted by the arc and the heating of the gas. The specific heat capacity of the gas is then used to compute the temperature rise, with values differing for constant volume and constant pressure scenarios. For example, using air in a sealed box, applying 1 kW of energy for 10 seconds results in a temperature increase of approximately 13.9 Kelvin. Understanding these principles allows for accurate calculations of temperature changes in enclosed environments.
pixelsnpings
Summary:: Given a known closed space/apparatus ( e.g. constant volume, pressure, density, current, temperature, voltage, spark gap distance - let me know if I missed something) how would I compute the change in gas temperature.
Hello,
Given a known closed space/apparatus ( e.g. constant volume, pressure, density, current temperature, voltage, current, spark gap distance - let me know if I missed something) how would I compute the change in gas temperature. Obviously, temperature is not the only perameter that would change, I'm just focused on that parameter for now.
Thanks!
Science news on Phys.org
Welcome to PF.
I would think that a first approximation would be to calculate the energy delivered to the gas (the electrical power to generate the arc multiplied by the arc duration in seconds). That energy would go into the light from the arc and the heating of the gas. I'm not sure in what proportions, though.
[Note -- Thread moved from the EE forum to the Thermo forum for better replies]
Hello,
Thanks!
I presume you measure the power supplied to the arc, and assume this is the power supplied to the gas. Then you apply the ordinary heating formula using the Specific Heat Capacity of the gas. For air at constant volume (sealed box) the figure I have found is 0.718 kJ/kg K, and at constant pressure (vented box) 1.01.
So supposing we have 1 kg of air in a sealed box and we apply 1kW of energy for 10 seconds, energy supplied is 10 kJ. Then the temp rise will be 10/0.718 = 13.9 Kelvin.
https://www.engineeringtoolbox.com/specific-heat-capacity-gases-d_159.html
Likes DaveE, Lnewqban and berkeman
@tech99, That is exactly what I need. Thank you so much!
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
