Calculating the Density of Wood with Archimedes' Question
  • Thread starter Thread starter jimithing
    Archimedes
To calculate the density of a wooden cylinder floating in water, the key relationship is between the buoyant force and the weight of the displaced water. The height of the submerged portion of the cylinder is crucial, as it directly influences the volume of water displaced. The density of the wood can be derived from the formula, showing that the radius of the cylinder is not necessary for the calculation. The final density of the wood is determined to be approximately 530 kg/m^3 or 0.53 g/cm^3, which aligns with the expectation that wood is less dense than water. This analysis confirms the principles of buoyancy and density in fluid mechanics.
jimithing
A wooden cylinder 30.0 cm high floats vertically in a tub of water (density 1.00 g/cm^3). The top of the cylinder is 14.1 cm above the surface of the liquid. What is the density of the wood?
Does the radius of the cylinder need to be known in order to relate height and volume? Obviously the 15.9 cm that is under water comes into play, but where exactly?
The up thrust force acts on the wooden cyclinder is equal to the weight of the wooden cyclinder when the cyclinder floats on the water.
The up thrust force is equal to the weight of the water displaced when the cyclinder floats on the water.
My answer : 5.3 X 10^{-3} kg/m^3
for this example, the radius of the cylinder is not important.
m\vec{g}=\vec{B} where B is buoyancy force.
=> V_c=\pi{r^2}H and V_l=\pi{r^2}{(H-h)}
=> \rho_c{V_c}g=\rho_w{V_w}g
=> \rho_c=\rho_w{\frac{\pi{r^2}{(H-h)}}{\pi{r^2}{H}
finally \rho_c={(1-\frac{h}{H}0}g/cm^3
well when you divide V_c by V_w the factor (pi)r^2 is removed.
H being the total height of the cylinder and h being the height of the cylinder under water, correct?
yes sir, that's correct, but be careful the answer is 530 kg/m^3 or .53 g/cm^3, and I think that is logic because the density of wood is < the density of water, and also see the proportion of h vs H ~.5 which agrees with this result.
