Calculating the distance of a sliding block
  • Thread starter Thread starter scryedzxp
    Block Sliding
To calculate the deceleration of a sliding block, the force of friction is determined by multiplying the coefficient of friction by the normal force, and the resulting deceleration can be found by dividing this frictional force by the mass of the block. The total distance traveled by the block can be calculated using kinematic equations for uniformly accelerated motion or energy methods, considering both the applied force and friction. When the applied force exceeds friction, the net force determines the acceleration, while once the push ceases, only friction acts to decelerate the block. Additionally, users are encouraged to clarify their specific problem scenarios to receive accurate guidance on calculations. Understanding these principles is crucial for accurately programming simulations of the block's motion.
scryedzxp
1) I would like to know if I found the deceleration correctly.
Since the force of friction is coefficient of friction * Normal Force, and F = ma, would the deceleration be force of friction/mass?
2) How do I calculate the total distance a sliding block traveled? (The block was pushed.)
If friction is the only force accelerating the block (for example, the block has a initial speed on a horizontal surface), then Newton's law tells you that a = F/m. Now if you use what you know about the friction force, what's the resulting acceleration? (What's the normal force?)
Several ways: (1) Using the kinematic relationships for uniformly accelerated motion, or (2) using energy methods.
The resulting acceleration would be the applied force plus the force of friction. Since the force of friction is opposing force to the applied force, it's basically subtracting the two values. Normal force is the positive value of the object's weight.
Which energy formulas would I use? Can you steer me in the right direction?
I'm a bit confused about the problem. Is there an applied force in addition to the friction? If that force exceeds the friction force, why would the block slow down?
In any case, the acceleration would equal the net force divided by the mass.
OK.
Again, please describe the problem exactly as it was given, so I don't steer you wrong.
If it's just a block being slowed by friction, the work done by friction in bringing it to a complete stop must equal (in magnitude) the initial kinetic energy of the block.
I'm writing a program and I need to know the pushed block's final distance. The user will input the amount of the applied force. I just have it so that the block is pushed for a second and it'll slide after that point. After it's been given a push, it'll have so-and-so speed and acceleration - and since the block is not on a frictionless surface, it is bound to slow down.
OK, much clearer. You'll need to break this into two pieces:
(1) While the push is being applied, there are two forces acting. Find the net force and thus the acceleration. Find the block's speed after one second (assuming it starts from rest).
(2) Once the push is removed, the only force is the friction. Find the new acceleration (or de-acceleration, if you prefer). You have the initial speed (from part 1), now find the distance it slides using kinematics (or by calculating the work done by friction).
really need help now now now please
hi
i have a few questions to ask.
firstly, I'm trying to calculate F(mu) and Fn using the F(mu)=Fg sin(theta) and Fn=Fg cos (theta) for the object and shoe for both the initial and added weight. THe angle is 37.7 degree's for object 1 and with weight is 42 degrees and the 2nd one is 40.3 degrees for object 2 and weight is 41.3 degrees.
also am having trouble determining things on excel but can someone add me to their msn and i'll explain further.
thanks heaps!
olivia
