Calculating the number of photons in a wave
  • Thread starter Thread starter Daintyg
    Photons Wave
The discussion revolves around comparing the number of photons emitted by a 100W light bulb and a 100W FM radio. Calculations indicate that the FM radio emits significantly more photons per second than the light bulb, due to the lower energy of radio photons compared to visible light photons. The energy relationship is defined by the equation E=hc/λ, where the wavelength plays a crucial role in determining photon energy. The conclusion affirms that the frequency of radio waves is much lower than that of visible light, resulting in a higher photon count for the radio. This highlights the importance of understanding photon energy in different electromagnetic spectrum regions.
Daintyg
I am trying to answer a relatively simple question. I have been asked to compare the number of Photons in 100W light bulb and a 100W FM Radio per second. Having crunched the numbers it appears that an FM Radio wave gives out more Photons per second than a light bulb. Is this correct?
I have used E=hc/λ
I come out at 2.87x10E20 for a light (Using yellow) and 5.03x10E36 for a radio (the power depends on the wavelength)
You are correct and presumably in your calculation you found that the energy of A radio photon is much less than the energy of a visible light photon.
A radio frequency is very much less than the frequency of visible light
Thank you, I was being a dumb arse.
No comment:smile:
except to say... don't look at yourself like that.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
