Calculating the pH of CO2 dissolved in 1l of water
  • Thread starter Thread starter skaai
    Co2 Ph Water
The discussion revolves around calculating the pH of a solution where carbon dioxide is dissolved in water at equilibrium. The setup involves 1 liter of water in a 100% carbon dioxide atmosphere at 25°C, leading to a calculated pH of approximately 3.92. Key calculations include determining the number of moles of dissolved CO2 and applying the pKa of carbonic acid to find the concentration of hydrogen ions. The participants acknowledge the complexity of accurately measuring carbonic acid concentration, often assuming all dissolved CO2 is in this form for practical calculations. Overall, the calculations appear sound, and the result is deemed reasonable for the given conditions.
skaai
OK folks,
first of all, let me thank those of you who have helped me with previous questions... perhaps this is why I keep coming back!
This time, I'm just asking those of you who are better than I am at this if I did this right and thus, got the correct result. I think I did, but since this is not a homework problem, I have no way of checking my answer...
I set up my problem like this (see the attached diagram):
Imagine our system has a beaker with 1 liter of water and is enclosed in a constant-pressure (of 1 atm.) atmosphere of 100% carbon dioxide at 25°C. We let the carbon dioxide come to equilibrium with the water so the maximum dissolves. What would the resultant pH be?
What do we know?
  • the pKa of carbonic acid is 6.367
  • the solubility of carbon dioxide in water at 25ºC 1atm is 1.45 gram/liter
  • we have 1 liter of water
What is the reaction?
CO2 + 2H2O → H2CO3 + H2O → HCO3- + H3O+
  • the number of moles of carbon dioxide that dissolve in water at equilibrium will equal the number of moles of carbonic acid in solution.
1.45 g. CO2\frac{1 mol.}{44.01 g.}= 0.032947 mol. CO2
Calculate using a RICE table (see the attached image table):
Convert pKa to Ka: 10-pKa = Ka → 10-6.367 = Ka
Ka (10-6.367) = \frac{[A-][H+]}{[HA]} = \frac{(x)(x)}{(0.0329-x)}​
can we apply the "rule of 500?":
Rule of 500: if \frac{[HA]}{Ka}>500, ignore any nonzero changes in "x"​
\frac{0.0329}{1x E-6.367}=76,594 >> 500 so yes.​
simplify Ka:
10-6.367=\frac{x²}{0.0329}​
x²=10-6.367(0.0329)=1.41317x10-8
x=√1.41317x10-8=1.18877x10-4=[H+]​
pH = -log[H+]=-log(1.18877x10-4)=3.9249≈3.92
so the lowest the pH can go in 1 liter of water in equilibrium with 100% CO2 at 25ºC and 1 atmosphere pressure is 3.92.
It sounds like a reasonable number, or did I totally mess something up somewhere?
thanks so much for any help on this!
Chemistry news on Phys.org
Looks OK to me.
Note that actually we don't know what is the concentration of carbonic acid in water - we can measure solubility and pH, but that allows only to calculate equilibrium constant for the overall reaction
H2O + CO2 <-> H+ + HCO3-
but not for two separate ones:
H2O + CO2 <-> H2CO3
H2CO3 <-> H+ + HCO3-
We often do assume all carbon dioxide dissolved is present in the form of carbonic acid, that yields commonly known Ka1 value. As it yields a correct calculation results we simply don't care about reality.
Likes 1 person
I see your point about carbonic acid... it's so mysterious, but all we can do is like with dark matter... infer its there from the effects...
thanks so much for the once-over!
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
