Calculating the Phase Spectrum from a Fourier Transform
7 replies · 7K views · last reply
dead_devil_66
Hi!
I'm trying to understand how do i get the phase spectrum from a Fourier Transform. From this site
http://sepwww.stanford.edu/public/docs/sep72/lin4/paper_html/node4.html#lin4_swhfactm
this statement
"The phase spectrum is usually calculated by taking the arctangent of the ratio of imaginary to real parts of the Fourier transform."
Yeah, right. So, when i have a sum of functions that are Fourier Transforms, how do i know which is the real part and the imaginary part of the entire sum?
[tex]Re[f(k)+g(k)]=Re[f(k)]+Re(g(k))[/tex]
and the same with imaginary part. Does this answer the question, or I misunderstood something?
it answer half of the things i asked. The unanswered part is how do i get the imaginary and the real parts of any Fourier transform?
I think I'm missing something. Ther real and imaginary part of a complex function are taken the same way you do for numbers... try giving an example so we can see where's the problem...
i have this function
[PLAIN]http://j.imagehost.org/0556/fun_ao_pre_trans_fourier.png
the Fourier transform is
[PLAIN]http://j.imagehost.org/0286/fun_ao_trans_fourier.png
now, how do i get the real and the imaginary parts??
Ah ok, the problem is then more about complex numbers than with Fourier transforms. You have to put the Fourier transform in the form a + jb, with a and b real numbers. Then a will be the real part and b the imaginary part. You go by steps:
1) The exponential decomposes like
[tex]e^{j\theta}=\cos\theta+j\sin\theta[/tex]
2) The inverse of a complex number is
[tex]\frac{1}{a+jb}=\frac{a-jb}{a^2+b^2}[/tex]
3) Oh and finally recall that [tex]j^2=-1[/tex] !
Using these 3 rules, you can, with a bit of patience, write your expression like a + jb. Try it yourself, if you don't get it we'll see.
dead_devil_66 said:
ok, but how do i do with the dirac function?
Treat the delta function just like an ordinary real function.
