Calculating the wall thickness of a vacuum chamber
Calculating the minimum wall thickness for a cylindrical vacuum chamber requires understanding the complexities of external pressure calculations, especially at ultra-high vacuum levels like 10^-9 Pa. The ASME Section VIII provides guidelines for pressure vessel design, but expertise is necessary to navigate its complexities effectively. Thin walls can lead to buckling and implosion risks, necessitating careful design considerations, including the use of hoops to maintain structural integrity. The discussion emphasizes the importance of using proper materials and construction techniques to ensure safety and functionality. For accurate calculations and safety, consulting with experienced professionals in vacuum vessel design is crucial.
David761
TL;DR Summary
I am designing a cylindrical vacuum chamber and need to calculate the minimum wall thickness to prevent implosion.
I have an inner radius of 0.96 m, an internal pressure of 10^-9 Pa and the external pressure is atmospheric (101,325 Pa). The material has a yield stress of 355 MPa.
Is there any simple equation that can be applied here to calculate the minimum chamber wall thickness? Thanks!
David761 said:
Summary:: I am designing a cylindrical vacuum chamber and need to calculate the minimum wall thickness to prevent implosion.
Welcome to the PF, David. :smile:
What is your background in Mechanical Engineering? Can you say more about this project? Do you have any help on the project, and more importantly are you working with an experienced Mentor who can ensure that you do this safely?
You mention the inner diameter of around 1 meter, but do not say how long it is. How are you planning on sealing the ends of the cylinder? Where are you going to put the hatch (with the exploding bolts)? :wink:
What vacuum pumps are you using to achieve 10^-9 Pa, and what is your anticipated pump-down time?
https://en.wikipedia.org/wiki/Ultra-high_vacuum
https://vacaero.com/wp-content/uploads/2012/02/figure-2_uhv_lg-1.gif
Likes jrmichler and Lnewqban
That's deep into the ultrahigh vacuum. You'll need special low outgassing materials, proper welds, expensive pumps, baking of the chamber, copper gaskets, and on and on. This will take a long time to get right and will be expensive.
Likes jrmichler and berkeman
No. If you use search term vacuum vessel design calculations, the very first hit starts of with "External pressure (vacuum) calculations start off more complex than internal pressure calculations, ".
That site also mentions that "The calculations are found in ASME VIII-1 UG-28". The last time I read through ASME Section VIII for pressure vessels, I believed the friend who told me that, in order to properly understand and use it, a person needs to work with Section VIII for a full year under the guidance of somebody who knows their way around that document.
That's in addition to Posts #2 and #3. If this is a real project, get a copy of ASME Section VIII, read it enough to understand that you are over your head, then find somebody that knows how to design vacuum vessels. If this is a homework problem, study your textbook to understand what assumptions and simplifications they are making, then post them along with a request to move this to the homework forum.
Likes berkeman and anorlunda
I think you can all relax a little. There is something about a hard vacuum that terrifies otherwise sane people. It is the high energy physics that goes on in a vacuum that can be dangerous.
https://en.wikipedia.org/wiki/ASME_..._-_Rules_for_Construction_of_Pressure_Vessels
That applies to vessels “having an internal or external pressure which exceeds 15 psi (100 kPa)”.
It should exempt vacuum vessels in the atmosphere, from requiring certification.
The stored energy in a vacuum chamber is negative. It can implode, away from you. Take care not to pinch your fingers.
The danger is essentially the same at 1 Pa and 10-9 Pa, that's not the point. It's significant for every internal pressure much lower than atmospheric, especially with a vacuum that large. An implosion can still come with smaller components shooting away at high speed.
Likes Dr_Nate and berkeman
The walls don't need to be very thick to prevent an implosion. The reason why UHV system has thick walls has to do with the need to be able to attach windows, flanges etc AND the fact that even solid metal will be somewhat porous to gases such as hydrogen.
Mfb is of course correct that there is no difference between 1 Pa and a nPa when it comes to the risk of implosion. Hence, any container that is designed to be operated below 1 Bar should be strong enough.
If you want to design something that can reach 1e-11 mBar the risk of implosion is probably the least of your concern.
The problem with thin walls is buckling. The cylinder is only strong while it remains cylindrical. For that reason hoops are needed to maintain the surface curvature if the wall is too thin. Any dent or elliptical deformation will cause an unbalance of forces that can initiate a catastrophic collapse.
The American Physical Society gives the following surprising demonstration of what can happen with thin walled vessels.
https://www.aps.org/programs/outreach/guide/demos/cancrush.cfm
Likes Tom.G and berkeman
Cool demo. Maybe should be posted in the "Physics Labs at Home" thread, since it's pretty easy for students to do while studying at home now. :smile:
Is the hydotest applied for vessel working with vacuum -.9bar only or not
What is "hydotest" ?
Hydro test = hydrostatic pressure test ?
