Calculating Time and Weight in a Lunar Cliff Drop
  • Thread starter Thread starter Sidearm
    Lightning
The discussion revolves around solving physics problems related to time delays of lightning strikes and the free fall of a rock on the moon. For the lightning strikes, the time delay can be calculated using the speed of light and sound, with the formula t = d/v. The second part involves calculating the time it takes for a 40kg rock to fall from a 60m cliff on the moon, using the equation for free fall, h = gt²/2. The weight of the rock can be determined by multiplying its mass by the moon's gravitational acceleration of 1.64 m/s². Overall, the thread provides guidance on applying physics equations to solve these specific problems.
Sidearm
i have a physics assignment and can't do a few questions, normally i would not resort to asking, but i am really stuck
1. 2 lightning strikes occur simultaneously 10km apart if an observer was 2km from one and 8km from another
a) find the time delay between the first flash and the second reaching him
b) the time delay between the sound of the closer strike and the distant strike reaching him,
2. if i dropped a 40kg rock over the edge of a 60m high cliff on the moon, where g = 1.64ms -1
a) how long would the rock take to reach the ground
b) what would the rocks weight be
Any help would be greatly appreciated, also if you could mention how to do this for future reference that would be great
1a) Do you know the speed of light? Its 3 x 10^8m/s
With this speed, and the distances, 8km, and 2km, find the time it takes to get him.
The equation for this is t = \frac{d}{v}
The time delay between two events is t_2-t_1
Now do the same with sound, sound has a speed of 340m/s, One million times less than the speed of light.
The numbers for a) will be pretty small, the numbers of b) will be a few seconds each.
2. You know the position equation for an object in free fall is:
x(t)-x_0 = v_0t + \frac{gt^2}{2}
Since there was no initial position (x-x_0) or initial velocity (v_0), the equation simplifies to:
h = \frac{gt^2}{2}
You can solve this for t by rearranging and taking the square root, from there a) should be fairly easy.
Weight is a measure of the force of an object due to gravity, what is the equation for force? You are given a mass, and an acceleration. Find the force.
thanx for your help.
it has helped heaps
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
