Calculating Time for Sliding Chain through Hole
The discussion centers on calculating the time it takes for half of a flexible chain to slide through a hole using conservation of energy principles. The initial parameters include a mass (M) of 1.4 kg, total length (L) of 2.6 m, and an initial hanging length (L0) of 0.3 m. The correct position function is identified as x(t) = (x0/2)e^(√(g/l)t) + (x0/2)e^(-√(g/l)t), leading to the time equation t = √(L/g)*arcosh((L-x0)/x0). The critical insight is that L represents the total chain length, not a variable length.
  • Understanding of conservation of energy principles in physics
  • Familiarity with hyperbolic functions and their inverses
  • Knowledge of differential equations and their applications
  • Basic mechanics involving mass and gravitational acceleration
  • Study the derivation of the conservation of energy in dynamic systems
  • Learn about hyperbolic functions and their properties
  • Explore differential equations related to motion under gravity
  • Investigate similar problems involving chains or pendulums in physics
Students studying physics, particularly those focusing on mechanics and dynamics, as well as educators looking for examples of energy conservation applications in real-world scenarios.
derravaragh
A flexible chain of mass M and length L lies on a frictionless table, with a very short portion of its length L0 hanging through a hole. Initially the chain is at rest. Find a general equation for y(t), the length of chain through the hole, as a function of time. (Hint: Use conservation of energy. The answer has the form y(t) = Ae^(γt) + Be^(-γt) where γ is a constant.) Calculate the time when 1/2 of the chain has gone through the hole. Data: M = 1.4 kg; L = 2.6 m; L0 = 0.3 m.
This problem has been asked before, and I've worked through it, but I can't seem to get it right. I've solved the position function to be:
which can then be solved for t to get:
Since I want the time when half the chain has gone though, I solve using L = 1.3 m, but I can't seem to get it. Any help on where I've gone wrong would be appreciated.
Shouldn't the variable x appear on the right hand side of your equation for t? You might double check how you got the expression for t.
Doesn't L denote the total length of the chain? So, you aren't free to let it be 1.3 m.
I realized where I went wrong, I had solved for the time t when the entire chain had fallen over the side, so I went back and solved for when x(t) = L/2. Thank you for your help.
  • · Replies 17 ·
  • · Replies 32 ·
  • · Replies 19 ·
