Calculating Time to Heat 52 Gallons of Water
  • Thread starter Thread starter Jason03
    Heat Time Water
6 replies · 3K views
Jason03
the problem I am working on asks to find how long it would take to heat 52 gallons of water in a hot water heater if 4800 watts is being used and the temperature needs to be raised from 60 F to 120 F...
My work is below...
http://i674.photobucket.com/albums/vv106/jason03_2009/hw1.jpg
on Phys.org
Jason03 said:
the problem I am working on asks to find how long it would take to heat 52 pounds of water in a hot water heater if 4800 watts is being used and the temperature needs to be raised from 60 F to 120 F...
My work is below...
I'm not used to working in those units, but your approach looks sound. Did you get the correct answer? If not, try converting into mks units, and re-calculating to see what answer you get.
Yea I am used to SI units as well...I just worked with the units given since the conversions were given...I guess I could try it the other way to if I did it correctly
good call...its 52 gallons.. but I did the correct conversion in my calculations...
Thanks!...Just checking to see if it was right...
