Calculating velocity of steam through orifice
To calculate the velocity of steam through an orifice in a piping system, it's essential to consider the pressure conditions and flow dynamics. The pressure upstream of the valve remains at 0.3 barG, while the downstream pressure will not be atmospheric due to the restriction caused by the orifice. Using nozzle flow equations can help determine the flow rate and velocity, but the velocity will vary along the discharge line and will not be constant. The maximum velocity occurs at the vena contracta, and the flow may become choked depending on the pressure conditions. For accurate calculations, it's recommended to consult technical papers such as those from CRANE and API.
tobitronics
Hi all,
First time poster here and I'm stuck with what for me seems to be a simple problem. The situation is this:
I have a 100mm diameter pipe connected to a steam kettle, which produces steam at a constant 0.3barG. This pipe is split up into 4 50mm pipes, each pipe has a valve at the end that can be opened and closed and an orifice downstream with a diameter of 37mm. The pressure after the valve is atmospheric (0 barG). The manufacturer has given me a figure of consumption of steam per hour, although I do not know under which conditions this number is calculated. The steam passing through has a temperature of 108C, which corresponds to the pressure.
I want to calculate the velocity of the steam when its passing through the orifice (and the velocity when no orifice is applied). I know it has something to do with bernoulli's law and I tried using the calculators at TLV.com, however I seem to get contradictory answers.
F.e. when I calculate the flow rate through the orifice and use that number to calculate the velocity through the pipe (flow rate is constant throughout the pipe?) I get results which would indicate that not using an orifice increases the velocity, which (of course?) is not true.
Can anybody point me in the right direction?
Thanks in advance!
The pressure downstream of your valve will not be atmospheric. As the RO is there to restrict the flow the pressure upstream will be 0.3 barg.
The flow through the orifice can be calculated using nozzle flow equations (See CRANE technical paper)
The length of line downstream of your RO also would affect the result. How much pipe is downstream of the RO? If you have a long length of line you should do a line sizing calculation applying a K factor for your RO.
The RO is there to cause a pressure drop, so the velocity downstream will certainly be greater. The max velocity through the RO will be at the vena contracta.
The velocity downstream of the RO will also not be constant. It will change depending on the pressure. The pressure at the discharge of the piping will be either atmospheric if the flow is not choked, or greater than atmospheric if the flow is choking. Either way the pressure will be greatest at the RO discharge and reduce along the pipe i.e the velocity will not be linear. It will increase along the discharge line.
Check out API Part 1/2 and Crane.
What was your method for calculating the velocity?
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
