Calculating Work done by a force
The discussion focuses on calculating work done by a force using the formula W = Fd. The user struggles with determining the force vector F and the displacement vector d based on given coordinates. They identify the force as 5 lbs directed along the vector 3i + 2j and seek clarification on how to express the displacement from (0,0) to (0,4). The conversation highlights the need to understand vector components and their roles in calculating work. Overall, the user is looking for guidance on applying these concepts to solve the problem effectively.
Eikcuhc
[URL]http://einstein.math.fsu.edu:9080/testbanks/wiley/math/1114ptF08/cch/images/qu.215.9.question.gif[/URL]
I know that
W = Fd where here it is
W = F * {\rightarrow}{\}AB
Also, that
(im sorry, this looks really ugly)
\stackrel{v\rightarrow}{} = ||v||(cos\alpha\stackrel{i\rightarrow}{}+sin\alpha\stackrel{j\rightarrow}{})
||v|| = sqrt(a2+b2)
I get stuck fairly quickly on this problem, my professor never went on it in class.
using the second equation, I get to the point of
v = (sqrt13)(cos+sin)
I am not sure what goes into the cos and sin portion of the problem, I am assuming it has something to do with the coordinates it gives, but other than that, I have no idea.
Ok, so your force is 5lbs in the direction of 3i+2j, so what is your force vector F?
The displacement is from (0,0) to (0,4), what is you displacement vector d equal to?
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
