Calculating work done by gravity
The problem involves calculating the work done by gravity on a 10kg bucket of water lifted vertically 3.0m at a constant speed. The discussion centers around the application of work formulas and the interpretation of direction in the context of physics.
  • The original poster attempts to calculate work using the formula Work=Force*Distance and questions the discrepancy with the answer key, which uses a different formula involving angle. Participants discuss the implications of directionality in work calculations and the appropriateness of different equations for the scenario.
Participants are exploring the relationship between the two work equations and the significance of direction in work calculations. Some guidance has been offered regarding the negative sign associated with work done by gravity, and the discussion reflects a mix of interpretations regarding the use of different formulas.
There is a mention of the answer key using a different gravitational acceleration value and the implications of using negative work to indicate direction. The original poster is also questioning the broader applicability of the equations discussed.
JustynSC
A 10kg bucket of water is lifted vertically 3.0m at a constant speed. How much work did gravity do on the bucket during this process?
Work=Force*Distance (what thought to use)
Wext=Fextdcosθ (what the answer key says to use.
My attempt got me as far as plugging in: Work=(9.8m/s2*10kg)*3.0m=(98N)*3.0kg=294J
***In the answer key they used 10m/s2 for gravity, but also had a negative answer of -300J. I assume that they used the negative as a direction, but is work a vector or scalar? Looking to understand why the way I did this does not yeild the same answer, and how the formula the keys says to use works?***
The force is in the opposite direction of motion, therefore work done by gravity is negative. You should change the sign of either the acceleration or the 3 meter distance, because they point in opposite directions.
Okay thanks I was thinking something along those lines, but why would the key ask to solve using that other equation? It seems more complicated than the way I did it. does my method only work in limited scenarios and the other has a broader range of uses?
Well, the equation with the angle is more general, but as your problem is one-dimensional you don't need that.
I see. In that case I will stick to my simple method :) Thanks!
In this case the angle is zero and Cos(0)=1 so both equations are the same.
  • · Replies 19 ·
