Calculating Work on a Spring for Stretching from 4 to 7 Feet
The problem involves calculating the work required to stretch a spring from a specified length to another, with initial conditions provided regarding the spring's natural length and work done at a certain extension. The subject area pertains to mechanics, specifically the behavior of springs and work-energy principles.
  • Participants discuss the calculation of work using the spring constant and the limits of integration. Questions arise regarding the interpretation of the stretching distances and the definitions of force and energy at the spring's natural length.
The discussion is ongoing, with participants providing insights into the calculations and questioning the assumptions related to the problem's setup. Some guidance has been offered regarding the interpretation of the stretching distances, but no consensus has been reached on the exact meaning of the problem statement.
There is ambiguity regarding whether the stretching is considered from the natural length to the total length or from the extension point. This has led to different interpretations among participants.
blessedcurse
The amount of WORK to stretch a spring 4 feet beyond its natural length of 2 feet is 10 ft-lbs. Find the work required to stretch the spring from 4 feet to 7 feet.
W=[tex]\int^{b}_{a}Fdx=\int^{b}_{a}kxdx=[kx^{2}/2]^{b}_{a}[/tex]
10=[tex][kx^{2}/2]^{4}_{0}[/tex]
10=k(16)/2-k(0)/2
10=8k
k=4/5
W=[tex][kx^{2}/2]^{b}_{a}[/tex]
W=4/5[tex][x^{2}/2]^{5}_{2}[/tex]
W=4(25)/10-4(4)/10
W=42/5
W=8.4 ft*lb
hi blessedcurse
this would probably go better in the physics forum...
But what is the force and energy stored in the spring at its natural length of 2ft?
F = kx applies when x is defined as the distance form equilibrium position...
When the spring is at it's natural position of 2 feet, x=0, so F is 0 and W is 0...
Is that what you're asking?
easier to update in new posts so i can keep track of what happens...
but yep - that looks better, first part is correct
there is some ambiguity in the 2nd part of the question whether it means:
~4ft-7ft total length (2 to 5 as you have done)
~4ft extension from natural poistion to 7ft (would give 4 to 7)
I fixed my previous post before you had posted, I thought... sorry!
I don't know... I read it as stretching it from 2 to 5 feet beyond its natural length...
