Calculation of InAS WurtZite bragg peak position
poul
Hey
If I have a InAs Wurtzite structure, and now the a and c parameter from tables. How can i calculate the distance between (1 0 3/2)_sur layers? (in surface coordinates)
I need it to find the angle of reflection, for a (1 0 3/2) WZ InAs peak.
Is it just so simple?
(1 0 3/2)_sur = (7/6 7/6 -5/6)_cubic (in cubic coordinates)
And then the distance is just
d=2*pi/G_hkl= a_cub / (sqrt(123/36))
And then i can just use braggs law
2dsin(angle)=wavelength
Not a 100% sure what you are asking, but as I understand it you want to find the 2θ angle of your peak in a diffractogram?
If so the calculation should be straight forward. I.e. use whatever miller indice you want, find the corresponding d- value (i.e. plane spacing) for your specific lattice and then use Bragg's law.
Keep in mind that the Wurtzite structure is hcp and the commutative restraints that puts on Miller indices.
Or you could just download PowderCell, enter the structure data, and let it calculate it for you!
If I misunderstood you, please let me know and I'll see if I can help.
Hope this is of use!
If you only want the scattering angle, then yes, it is that easy.
Otherwise you have to figure out the exact relation between the standard and surface reciprocal space bases.
How to calculate diffractometer angles from that is very nicely described by Busing and Levy (1967).
http://scripts.iucr.org/cgi-bin/paper?a05492
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
