Calculations of how much water evaporated and what is left
The discussion revolves around calculating the amount of water remaining after heating and evaporating some of it. Initially, the user calculated the total energy required to heat and evaporate 300 grams of water, concluding that 135 grams evaporated after adding 350 kJ of heat. However, it was pointed out that the calculations should account for the total heat used to first raise the water temperature to 100 °C before considering evaporation. After correctly calculating the heat used for heating, the user determined that approximately 190 grams of water would remain after evaporation. The final conclusion is that the logic of the revised calculations is sound, leading to a more accurate estimate of the water left.
apbuiii
Suppose you put a coffee pot containing 300 g of water at 20 C on the stove. You then add 350 kJ of heat to the water, which heats the water to 100 C and the water starts to boil. After all the heat is added to the water, then how much water do you still have left? The heat of fusion for water is 6.01 kJ/mol and the heat of vaporization is 40.7 kJ/mol.
q=mass(specific heat)(Tf-Ti); q=moles(delta-enthalpy)
I first found how much energy it would take to evaporate all of the 300 grams. (100-20)(300g)(4.18) + (40.7 KJ)(300)(1mol/18g)(1000J)= 778653 J. So I then set up a ratio that if 778653 evaporates 300 grams then how many grams will 350000 J evaporate. 778653/300 = 350000/X. That gave me 135 grams evaporated. So I then minused that from the 300 giving me 165 grams left. Seemed reasonable to me but I got it wrong! Please help, but showing the steps to find the answer would be even more helpful! Thanks
There are two heat sinks - one (water heating to 100 °C) doesn't depend on the amount of evaporated water, other (water evaporation) depends. When you use ratio it is equivalent to assumption that you have heated only part of water, while you have to heat it all.
Calculate how much heat was used to heat the water, excess heat was consumed by evaporation.
Okay, so I did (300)(4.18)(100-20)= 100320 J. Then I subtracted that from 350000J to get 249680 J. This is where I get a little confused... Do I then do this: 249680=mols(40.7KJ)(1000J). That gave me 6.13 moles of water and then I change that to grams to give me 110.4 grams of water that it can evaporate. I then subtract 300-110.4 to give me the grams of water left 190 grams. Is that correct? Thank you so much...
I have not checked the numbers, but the logic is OK.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
