Calculte growth is some direction question
  • Thread starter Thread starter khdani
    Direction Growth
khdani
i know that the maximal growth is the gradiend of a function.
the formula is:
<br /> <br /> \triangledown f=f_x&#039;\vec{i}+f_y&#039;\vec{j}+f_z&#039;\vec{k}<br /> <br />
so when i am given a function
f(x,y,2x^2+y^2)=3x-5y
i am was told that it growth on point M(1,2,6) in direction
\hat{a}=(\frac{1}{3},\frac{2}{3},\frac{2}{3}) is 1
what is the gradient of f (maximal growth).
i tried to get it like this:
first of all i need a function which looks like this f(x,y,z)=...
in order to find the gradient
i don't know how to do the gradient of a function which i was given.
if i substiute the point
f(1,2,6)=3-10=7
i know i should write
<br /> <br /> (grad f(1,2,6)\dot \hat{a}=1<br /> <br />
Hi khdani! :smile:
(have a grad: ∇ and a curly d: ∂ and try using the X2 tag just above the Reply box :wink:)
That's right :smile:
or better still, f(x,y,z) = g(x,y) where g = 3x - 5y.
Now z = 2x2 + y2,
so, using the chain rule, df/dx = … ?, df/dy = … ?, df/dz = … ? :wink:
"so, using the chain rule, df/dx = … ?, df/dy = … ?, df/dz = … "
what?
you say i would substitute z with2x^2+y^2
so i get
f(x,y,z)=3x-5y
so f&#039;_x=3
f&#039;_y=-5
f&#039;_z=0
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
