Calculus, Analytical demonstration
araveugnitsug
Demonstrate Analytically:
If \lim_{x\to a}f(x)=L and L<0, there exists a δ>0 so that x\inDom(f), 0<|x-a|<δ \Rightarrow f(x)<0
2. The attempt at a solution
I start identifying what I want to demonstrate and what are my assumptions.
I'm aware I have to reach f(x)<0 from the fact that L<0 and using the definition of a limit, the x belonging to the domain is there so that it also covers the cases were if not stated, one could get a limit that does not exist due.
So I have:
0<|x-a|<δ and 0<|f(x)-L|<ε
and I suspect the way is not in the delta part but working with 0<|f(x)-L|<ε, but because epsilon is in relation to delta it never banish, meaning I would have to work with the other part.
0<|f(x)-L|
Because L<0 is part of the hypothesis
L<|f(x)-L|+L
L-|f(x)-L|<L
Triangle Inequality
L-|f(x)|-|L|<L
L-|f(x)|-(-L)<L
L-|f(x)|+L<L
L-|f(x)|<0
-|f(x)|<-L
L<-f(x)<-L
-L>f(x)>L
And I don't know where else to go to get the f(x)<0 form, I simply have no way to get rid of the L in the process without being left with an absolute value on f(x).
Using the defintion of limit, take \epsilon to be any number less than L.
It works wonderfully and makes it two simple steps. Thanks.
Though I'm inclined to ask; is this something that can always be done, correlating epsilon with the actual limit?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
