Calculus, center of mass
In summary: I'm not sure what you mean by "the density is inversely proportional to its distance from the origin". If you mean p= k/r then, since you are given that, take the integral of that over the region.In summary, the problem is to find the center of mass of a 2-dimensional plate that lies outside a circle with center at (0,1) and radius 1, but inside a circle with center at (0,0) and radius \sqrt{2}. The density of the plate is inversely proportional to its distance from the origin and the boundaries of integration can be found by solving for the intersection points of the two circles. The problem can be solved by breaking it into three separate integr
retroglam
Find the center of mass of the 2-dimensional plate which occupies the region inside the circle x^2 + y^2 = 2y, but outside the circle x^2 + y^2 = 1, and for which the density is inversely proportional to its distance from the origin.
m = integral (p(x,y)) dA
-> m = integral k/r
x^2 + (y-1)^2 = 1
It's not the integration itself I'm having trouble with just finding the boundaries of integration as they are between the two circles, any help/hints would be appreciated.
Thanks!
From looking at a graph of the two circles, it appears that the two intersection points occur between the upper half of the circle x2 + y2 = 1 and the lower half of the circle x2 + (y-1)2 = 1. That is, between the functions
[tex]y = \sqrt{1-x^2} \qquad \text{ and } \qquad y = 1-\sqrt{1-x^2}.[/tex]​
From here you can find the intersection points.
First, do you see, from symmetry, that [itex]\overline{x}= 0[/itex]?
The region you seek lies outside the unit circle but inside the circle with center at (0, 1) and radius 1. Those intersect where [itex]x^2+ (y-1)^2= 1= x^2+ y^2[/itex] or [itex]y^2- 2y+ 1= y^2[/itex] so [itex]y= 1/2[/itex]. Then [itex]x= \pm\sqrt{3}/2[/itex].
There is a slight complication in that the circle actually extends to x=-1 and x= 1 so it is probably best to do this in three separate integrals.
1) x from -1 to [itex]-\sqrt{3}/2[/itex], y from [itex]1- \sqrt{1- x^2}[/itex] to [itex]1+ \sqrt{1- x^2}[/itex] (from solving [itex]x^2+ (y- 1)^2= 1[/itex] for y).
2) x from [itex]-\sqrt{3}/2[/itex], y from [itex]\sqrt{1- x^2}[/itex] (the lower circle) to [itex]1+ \sqrt{1- x^2}[/itex]
3) x from [itex]\sqrt{3}/2[/itex] to 1, y from [itex]1- \sqrt{1- x^2}[/itex] to [itex]1+ \sqrt{1- x^2}[/itex].
What is Calculus?
Calculus is a branch of mathematics that studies continuous change and is primarily concerned with two main concepts: derivatives and integrals. It is used to solve complex problems related to rates of change, optimization, and motion.
What is the center of mass?
The center of mass is the point at which all the mass of an object can be considered to be concentrated. It is the average position of all the mass in an object, taking into account its shape, density, and distribution.
How is Calculus used to find the center of mass?
Calculus is used to find the center of mass by using integrals to calculate the weighted average of the position of each small mass element in an object. This process is called finding the "first moment of mass".
Why is finding the center of mass important?
Finding the center of mass is important because it helps determine the balance point of an object and its response to external forces. It is also used in engineering and physics to analyze the stability and motion of objects.
What are some real-world applications of Calculus and the center of mass?
Calculus and the center of mass have many real-world applications, such as determining the optimal shape and weight distribution of buildings and bridges, designing efficient and stable vehicles, and predicting the behavior of projectiles. It is also used in fields such as astronomy, biology, and economics.
