Courses Maximizing Success in Calculus Course: Balancing Understanding and Practice
  • Thread starter Thread starter BioCore
    Calculus Course
In a discussion about strategies for succeeding in an advanced university calculus course, participants emphasized the importance of balancing concept comprehension with problem-solving practice. The consensus is that students should focus on understanding the concepts thoroughly while also completing a sufficient number of practice problems to reinforce that understanding. It was noted that doing more problems than assigned can be beneficial for grasping the material. One effective approach mentioned is to read the entire chapter before and after class to enhance understanding, as this can make problem sets easier to tackle. Ultimately, mastering the concepts and being able to apply them in problem-solving is crucial, as exams often test both understanding and application of calculus principles.
BioCore
I am currently taking a basic Calculus course, well actually its an advanced class in university. I was wondering if you could advise, as to what would be better. Would it be better that I try to fully understand all the concepts in the course and do a moderate amount of questions for homework or practice, or would it be better to do as many questions as possible and just get the hang of concepts so I can try and pass.
Currently everyone tells me to do only the assigned work, which I take would mean that I should understand all the questions first. So what is your advice.
You should probably do as many problems as are necessary for you to understand the concepts. If you need to do more problems than are assigned, that is certainly fine (and not uncommon).
Yeah whatever works for you the best. The goal is to understand the topic/concepts, so however many problems you need to do for that to sink in is what you should do.
Speaking from personal experience I usually read the entire chapter/unit my class is working on before we start it in class. Then I go back and re-read it all again afterwards, and usually the concepts have sunk in and problems sets are pretty straight forward from there. Just one suggestion^^
Just learning the concepts as much as possible is great until you get a test asking for mainly applications of what you know. If its really an advanced calc course then you may be tested on proofs and such but I imagine it will still be mostly applications, ie. you may have one or 2 questions like state and prove the mean value theorem, but most will be find the 1st, 2nd and third derivatives of the following function... or calculate these given integrals...
what I am saying is that generally doing the assigned homework should help you learn the concepts but also prepare you for the test.
The two are not mutually exclusive: understanding the concepts means precisely being able to solve problems and solving problems will help you understand the concepts.
I'm going to make this one quick since I have little time. Background: Throughout my life I have always done good in Math. I almost always received 90%+, and received easily upwards of 95% when I took normal-level HS Math courses. When I took Grade 9 "De-Streamed" Math (All students must take "De-Streamed" in Canada), I initially had 98% until I got very sick and my mark had dropped to 95%. The Physics teachers and Math teachers talked about me as if I were some sort of genius. Then, an...
Bit Britain-specific but I was wondering, what's the best path to take for A-Levels out of the following (I know Y10 seems a bit early to be thinking about A-levels, but my choice will impact what I do this year/ in y11) I (almost) definitely want to do physics at University - so keep that in mind... The subjects that I'm almost definitely going to take are Maths, Further Maths and Physics, and I'm taking a fast track programme which means that I'll be taking AS computer science at the end...
After a year of thought, I decided to adjust my ratio for applying the US/EU(+UK) schools. I mostly focused on the US schools before, but things are getting complex and I found out that Europe is also a good place to study. I found some institutes that have professors with similar interests. But gaining the information is much harder than US schools (like you have to contact professors in advance etc). For your information, I have B.S. in engineering (low GPA: 3.2/4.0) in Asia - one SCI...
