Finding Solutions to x Goes to Infinity and Beyond
  • Thread starter asdfsystema
  • Tags
    Infinity
In summary: Yes, sorry. I meant "on" (-inf, +inf).81. Let f(x) = {2x^2+3 x -65) / (x-5)Show that f(x) has a removable discontinuity at x=5 and determine what value for f(5) would make f(x) continuous at x=5.Must define f(5)=You must define f(5) to be the limit as x approaches 5. f does not have a value at x= 5, given by that formula, because the denominator is 0 at x= 5. But in order to have a limit at x= 5, the numerator must also be 0. And
asdfsystema
87
Hey guys. I tried solving these on my own, but I cannot seem to find out how to do this.
23. What are the steps to finding
sqrt(3+6*x^2)/(2+5*x) as x goes to infinity?
41. Find the Horizontal Asymptotes for
17x/(x^4+1)^1/4 . I'm pretty sure its 17/1, but for some reason, my teacher asks for two, and I thought rational functions only have one horizontal asymptote...
62. f(x)= 4x^3+13x^2+11x+24 / x+3 when x<-3
f(x)= 3x^2+3x+A when -3 less than or equal to x
What is A in order for it to be continuous at -3?
79. f is continuous at (-inf, + inf)
f(y) = cy+3 range is (-inf,3)
f(y) = cy^2-3 range is (3,+inf)
what is C?
Must define f(5)=
Thank you so much in advance >< I've been doing these questions for 3 hours ... I need help to prepare for my calculus test next week !
If you tried, what did you do? It is always better to show what you have tried. One thing you can do is say "if x is extremely large, we can ignore "3" in comparison with 6x2 and "2" in comparison to 5x. What do you get if you just drop the 3 and 2?
A little more rigorous is to divide both numerator and denominator by x. While "going to infinity" is a nuisance, going to 0 is easy- and when x goes to infinity, 1/x goes to 0.
No, that is not necessarily so. "Horizontal asymptotes" occur is the graph approaches a horizontal line as x goes to infinity or negative infinity. What happens if x is a large negative number? For example, what is the value if x= -100000000?
What is the definition of continuous? In particular, what are the limits as x goes to -3 from above and below?
what is C?
This makes no sense. First you must mean "on" (-inf, +inf), not "at". Second, do you mean "domain" rather than "range"? And, finally, the only way that would make sense is if the two domains are (-inf, 3] and [3,+inf). Assuming those are correct, what are the limits as x goes to 3 from above and below?
Must define f(5)=
You must define f(5) to be the limit as x approaches 5. f does not have a value at x= 5, given by that formula, because the denominator is 0 at x= 5. But in order to have a limit at x= 5, the numerator must also be ____. And what does that tell you about factoring 2x2+ 3x- 65?
HallsofIvy, thanks for replying. I will try to post up what I did here.
i figured out the answer is sqrt(2) x sqrt (3) / 5 I don't get what I'm supposed to do to the numerator with the square roots.
What I did is turn that function disregarding the +2 and +3 so I got sqrt 6x^2 / 5x ... and I'm not suer what I do next...
17x/(x^4+1)^1/4 . I'm pretty sure its 17/1, but for some reason, my teacher asks for two, and I thought rational functions only have one horizontal asymptote...[/quote]
What I did first is fix the denominator and make it become 17x / x+1 because I multiply the roots. I disregard the +1 and get 17x/x ... This has two horizontal asymptotes?
I thought because the ratio of the coefficient of 17x and x is 1 , n=m=1 therefore it is 17/1 ? please correct me if I'm wrong . if x is -10000 then it is neg infinity .
What is A in order for it to be continuous at -3?[/quote]
continuous means there are no breaks , basically being able to draw it on a graph without lifting up pencil. also there is no discontinuity. as x goes to -3 when x<-3 it goes to 0?
I still don't understand what A has to be...
what is C?
Sorry I did mean on, and yes it is the domain. the limits as x goes to 3 from above is -inf ?
Must define f(5)=
factoring 2x^2+3x-65 would give me (2x+13)(x-5) so i'll cancel out and get (2x+13). So do I use direct substitution? f(5)= 2(5)+13 = 23?
Thanks for all the help . I appreciate it. I tried to make the colors different so it won't seem too confusing.
Well, what is [itex]\sqrt{6x^2}/5x[/itex] for x positive?
To see that you can "disregard" the +2 and +3, divide both numerator and denominator by x. Since x is going to infinity it is not 0 so we certainly can do that and see that [itex]\sqrt{2+ 6x^2}/(2+5x)= \sqrt{2/x^2+ 6}/(2/x+ 5)[/itex]. Now, as I said before, as x goes to infinity, 1/x goes to 0.
What happened to the fourth power and 1/4 power? (x4+ 1)1/4 is NOT equal to x+1. In fact, even (x4)1/4 is not equal to x- it is equal to |x|. Do you see why you get two different asymptotes?
And, why in the world would you think doing any calculation (where the denominator is not 0) would give "infinity"? If x= -10000, 17x/(x4+1)1/4 is -170000/10000.00000000000025= -16.999999999999999575, not anywhere near "infinity"!
Is there any reason you keep writing "17/1" rather than "17"?
No, that is not the definition of continuity, it is a general property. The definition of "continuity of f(x) at x= a" requires three things: 1) f(a) exists; 2) [itex]\lim_{x\rightarrow a} f(x)[/itex] exists; 3) those are equal: [itex]f(a)= \lim_{x\rightarrow a} f(x)[/itex].
Of course, the limit exists if the two "one sided limits" exist and are the same. Often you can find the limit of f(x), as x goes to a, by finding f(a) because, often, the functions we work with are continous. If you try finding the limit of f(x) as x approaches -3 "from below" by evaluating (4x3+13x2+11x+24) /(x+3) by evaluating at x= -3, you get 0/0 so that doesn't work. But the fact that the numerator is 0 at x= -3 tells us that x-(-3)= x+ 3 is a factor. Find the other factor so you can cancel the "x+ 3" terms and find the limit.
The limit from above, [itex]lim_{x\rightarrow -3^+} 3x^2+ 3x+ A[/itex] is easy: it is a polynomial, so continuous so the limit is 3(-3)2+ 3(-3)+ A= 27- 9+ A= 18+ A.
In order that the given function be continuous at x= -3. Those two limits must be the same. Set them equal and solve for A.
what is C?
Both "parts" of this function are polynomials and so the limits "from below" and "from above" can be found by evaluating them. What is c(3)+ 3 and c(32)- 3? Set them equal and solve for c.
Must define f(5)=
Yes, that's right. (2x+13)(x-5)/(x-5)= 2x+13 as long as x is not 5, and the limit as x approaches 5 depends only on what the value is for x close to 5, not equal to 5. Since (2x2+ 3x- 65)/(x-5)= 2x+ 13 for all x other than 5, they have the same limit at 5. and since 2x+ 13 is a polynomial, it is continuous and its limit is its value at x= 5.
41. horizontal asymptotes are 17 and -17 then ?
62. i still don't really understand... what do you mean by x-(-3)= x+ 3 is a factor? i don't get the 4x^3+13x^2+11x+24/ x+3 when x<-3 part but I understand the other
81. the answer is 23 then?
79. the answer is 1 ?
another question is:
the vertical asymptote of -x^3/x-2 is x=2 right ?
sorry this is my first year learning calculus and I am not that familiar with the rules yet
Yes, the horizotal asymptotes are 17 and -17.
If p(x) is a polynomial and p(a)= 0, then (x- a) is a factor of p(x): p(x)= (x-a)q(x) where q(x) is a polynomial of lower degree. In this case, since 4(-3)3+ 13(-3)2+ 11(-3)+ 23= 0, 4x3+ 13x2+ 11x+ 24= (x+3)q(x). You can find q(x) by dividing 4x3+ 13x2+ 11x+ 24 by x+3 (it was for precisely this purpose that "synthetic division" was developed). To put you out of your misery, 4x3+ 13x2+ 11x+ 24= (x+3)(4x2+ x+ 8). What is (4x3+ 13x2+ 11x+ 24)/(x+3)?
There are two parts to the question: the first is to show that there is a removeable discontinuity. You can do that by showing that the limit of the function, as x goes to 5, exists. Then the answer to the second part is that limit which is, yes, 23.
Yes, 9c- 3= 6c+ 3 gives c= 1.
Yes, that fraction is not defined at x= 2 so the graph cannot cross that vertical line. That is a vertical asymptote. (Notice that the graph cannot cross a vertical asymptote but can cross a horizontal asymptote. That is the because the definition of "function" does not allow two (x,y) points on the graph to have the same x value, but does allow two points with the same y value.)
thanks i understand now . sorry for the trouble
1. What is the concept of "x goes to infinity and beyond"?
The phrase "x goes to infinity and beyond" refers to the idea of finding solutions to problems or equations where the variable x is approaching infinity. This means that x is continuously increasing without limit and we are trying to determine the behavior or outcome of the equation as x gets larger and larger.
2. Why is finding solutions to x going to infinity important?
Finding solutions to x going to infinity is important because it helps us understand the behavior of equations or systems as they approach infinite values. This can have real-world applications in fields such as physics, engineering, and economics.
3. How do you find solutions to x going to infinity?
The method for finding solutions to x going to infinity depends on the specific problem or equation. In general, it involves analyzing the behavior of the equation as x approaches infinity, looking for patterns or trends, and using mathematical techniques such as limits and asymptotes to determine the solution.
4. What are some common challenges when finding solutions to x going to infinity?
One common challenge when finding solutions to x going to infinity is determining the behavior of the equation at infinity. This can be difficult if the equation is complex or if there are multiple variables involved. Another challenge is identifying and understanding any asymptotes or discontinuities in the equation.
5. How can finding solutions to x going to infinity be applied in the real world?
Finding solutions to x going to infinity can be applied in various real-world scenarios such as calculating the maximum height of a projectile, determining the long-term growth of a population, or predicting the behavior of a stock market trend over time. It can also be used to study the behavior of natural phenomena, such as the trajectory of a planet or the flow of a river.
