Calculus II - Taylor Series Question
9 replies · 3K views · last reply
GreenPrint
Find the power series for f(x) using the definition of taylor series expansion about a=9. f(x)=1/sqrt(x)
f(x) = 1/sqrt(x) => f(9) = 1/3
f'(x) = - 1/(2 x^(3/2)) => f'(9) = -1/54
f''(x) = (1*3)/(2^2 x^(5/2)) => f''(9) = 1/324
f'''(x) = -(1*3*5)/(2^3 x^(7/2)) => f'''(9) = 5/5852
The patter that seems to be developing is
f^(k)(x) = ( (-1)^k ?)/(2^k x^(1/2 + k) )
but I'm lost as to how to express the pattern that appears in the numerator, hence the question mark, of each order of the function
for f(x) we have 1
for f'(x) we have 1
for f''(x) we have 1*3
for f'''(x) we have 1*3*5
The patter that seems to appear after the 1st derivative in a sort of backwards batter, 5*3*1 instead of 1*3*5, is (2k-1)(2k-3)(2k-5)... until the last term is equal to 1
I'm sort of lost... thanks for any help!
Why are you lost? You found the answer?
The thing you might do first is to prove (by induction) that this is indeed the pattern that is emerging in the numerator!
The problem is that I don't know how to come up with the series representation of the function because I don't know how to describe the pattern in the numerator with mathematical functions
inf
sigma ( (-1)^k*1*3*(2k-1)*(x-9)^k)/(k!*2^k x^(1/2 + k) )
k=0
I don't know what to do about the question mark because I don't know how to describe the pattern with mathematical functions... maybe I'm over thinking it
How would I write the series representation without a double factorial?
or how about
[tex]1.3...(2n-1) = \Pi_{i=1}^{n}(2i-1) = \frac{(2n-1)!}{2^{n-1}(n-1)!} = (2n-1)![/tex]
inf
k=0
for k =0
( (-1)^0*1*3*...*(2*0-1)*(x-9)^0)/(0!*2^0 x^(1/2 + 0) )
(1*3*-1)/sqrt(x)
-3/sqrt(x)
it doesn't seem to work because of the 2*0-1 is negative 1 and doesn't cancel out the 1*3 to leave me with one in the numerator to give me f^(0)(x) = 1/sqrt(x) but instead -3/sqrt(x)?
I guess I should learn double factorials than but it's not a standard calculus II topic so that's why I was lead to believe I was doing something wrong but I guess I'm not because I had no clue how to represent the pattern in the numerator
You may have to write the sum from k=1 onwards for that reason though i haven't checked.
If you read post #7 there is a couple of different ways to write it. The double factorial is just a nice shorthand for these, but doesn't get used very often in my experience. If I were marking, any of the forms in post #7 would be fine.
The main thing is you recognised the pattern. As micromass points out if you want to be rigorous you should use induction to prove this is the pattern. However looking at the action of the derivative it should be easy to convince yourself it is correct.
