Calibrating a Hall Probe for Magnetic Flux Density Measurements
  • Thread starter Thread starter wynitia
    Probe
To calibrate a Hall probe for measuring magnetic flux density, it is essential to position the probe in a known magnetic field, which can be achieved using a Helmholtz coil for uniformity. For accurate measurements between two bar magnets, ensure they are aligned collinearly and use a ruler or a custom guide to maintain the probe's midpoint. Calibration involves plotting voltage (V) against magnetic flux density (B), where B can be determined from established magnetic field values or reference materials. Avoid using magnetic materials for the apparatus to prevent interference. Proper setup and calibration are crucial for reliable experimental results.
wynitia
Hi there! I am have to plan an investigation. I have to calibrate a Hall probe to measure magnetic flux density and then investigate how the separation between two bar magnets has an effect on the magnetic flux density.
Can anyone help with calibrating a hall probe? I have searched the net and textbooks but they all tell you about the Hall effect and not a steo by step calibration method.
Also how can I be sure I am keeping the Hall probe directly between two bar magents? do I need a guide, or hover over a ruler to measure the distance (making sure I am exactly half way between two mountd bar magnets)
PLEASE HELP!1
Im so stuck and any help would be sooo appreciated.
Thanks guys
XXXXX :confused:
Look at some of the threads here : https://www.physicsforums.com/search.php?searchid=175889
Specifically, see : https://www.physicsforums.com/showthread.php?t=70290&highlight=hall+probe
As for the measurement, find some way to position the magnets collinearly and then, you could either build a guide (with graduations on it) or simply use a ruler to define the midpoint. Just make sure all parts of the apparatus are non-magnetic (skip iron and steel things).
Thank you for your speedy reply!
I think I checked out a forum, maybe it wad that one. Just one thing, if you're still online, when they say place the probe in a known field, how do know the field?? I am gettin my headin a muddle haha The graph for calibration is B against V yeh? Well you measure V on the voltmeter but how do you know B?
Thank you again
xxxxxx
Even though I haven't read the other forums, I would suggest a Helmholtz coil. Check out http://www.netdenizen.com/emagnet/helmholtz/idealhelmholtz.htm on how the Helmholtz coil pair works.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
