heloman30
- 9
- 1
I'm working on this to further my understanding of parts used in an aircraft braking system.
Using known weight, and constant acceleration determine braking moment for a tricycle gear airplane with two main landing gear brakes.
Mass- 12,292 kg
Acceleration: -1.4 m/s^2
Tire radius: 0.4445m
Brake Key Radius: 0.1016 (10 keys)
Is it possible to determine brake moment at wheel- to- brake keys (a specified radius inside the wheel) using the above information? This would be similar to determining the braking moment on a car wheel lug during deceleration.
F=ma
The aircraft has a deceleration force of 17,264.6 N, how do I use this information to determine braking moment, at a specified radius, ignoring wind, rolling resistance ect?
Googling I found the following equation: T = (BFw)(R)/ r
Where
T = Torque (Nm)
BFw= Brake Force wheel
R = Static laden wheel radius
r= Speed Ratio between wheel and brake
Is it correct to divide the linear force in half, for two wheel brakes, and use the result for BFw?
If so I come up with
T=16793.3 Nm converted= 12,385.36 Ft lbs
BFw= 8632.3
R= 0.4445m
r= 0.22857 (35" inch tire diameter to 8 inch "brake key" diameter )
