Can a Diode Protect a Transistor from High Voltage?
  • Thread starter Thread starter manshuk89
    Diode Transistor
A diode can be used to protect a transistor from high voltage, particularly when dealing with inductive loads. A reverse-biased diode placed across the load can absorb voltage spikes that occur when the transistor turns off, preventing damage. It is essential to ensure that the transistor has adequate voltage ratings to handle potential transients. Additionally, using a Zener diode or other protection devices can enhance safety, but they should not replace the need for properly rated transistors. Proper circuit design is crucial for effective protection against high voltage in applications like controlling an electronic lock.
manshuk89
i want to protect my transistor(working in saturation) from high incoming voltage...
can a diode be used to protect it from the high voltage?
It would help to have more information. Normally you would use a Zener diode (reverse biased) as a uni-directional transient supressor, but there are other options available as well.
Yes - a circuit would help.If a transistor is saturated, it is unlikely to have a high voltage across it! You'd expect less than 1V.
Well, if it's really always saturated why not be done with and replace it with a wire? Seriously though, as others have said we need more information. What is the circuit, what does it do?
If you are actually referring to protecting the device when it is OFF, or in the process of turning off, that's another matter. Properly chosen protection devices (TVSs etc.) can often safely absorb more energy from such things as switching transients. Note however that these things are no substitute for transistors with adequate voltage ratings.
In fact, it may be necessary to use a higher voltage transistor than might otherwise seem to be necessary, in order to be sure that the protector absorbs the energy without the transistor avalanching. Some otherwise excellent protection devices have (in my opinion) surprisingly vague voltage ratings.
further information:-
the transistor is being used to control an electronic lock.the device switches between cut off and saturated region.
the collector is connected to a lock which is further connected to 12 volt dc.
when there is no current on base the transistor is in cut off- infinite impedence.
it can be said that the lock is being used as a relay. wen the microcontroller provides 5 volt at the base , the transistor goes into saturation and conducts.
the lock requires 12vdc and 3A CURRENT to operate.
how to protect the transistors against such ratings?
So you want to protect against transients when yo try to turn off an inductive load.
One way to do it is to put the diode across the load (in parallel with the lock) but 'upside down', so it is reverse biased, normally and will take no current. When the transistor 'tries' to turn off (reducing the current) a voltage spike will occur, due to the inductance, which would take the collector volts way above Vcc (positive). The diode will stop this happening by shorting out the inductance when its volts are above Vcc. As long as the transistor will survive Vcc, it will not be harmed.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
